two separate PCB in one sheet
asadi.siyavash
Member level 4
Member level 4
I want to reduce manufacturing cost so I decided like in Altium designer create one sheet that exist two separate PCB that I draw before.In altium designer by using keep out layer, I could delineate each board size and then simply I copy both PCB and paste them in new PCB sheet and when I sent it to manufacture without any problem they separate two PCB, I think it is possible in cadence allegro but I don't know how I can do this.
Any help would be greatly appreciated,
Sincerely yours,
Siyavash.
Hi Asadi,
I agree with marce. It is a good practice to panelise the Gerber of both your boards and send it for manufacture.
Don't Mix it up in your design.
Thanks,
SHABU
really thanks for your replays but I don't know how I can panelise the gerbers, can you describe.
sincerely yours,
Siyavash.
You need a decent software for handling Gerbers such as CAM350, or better still produce a drawing showing the board outlines in the panel and ask your PCB manufacturer to panelise the Gerber data for you.
