firegod88
Newbie level 3
Hi I have a design that needs a 12v DC from an ATX PSU on the board running to everything that needs 12v, I have a serial device that needs 24v but it's logic tx and rx are derived from the 12v part of the circuit. I have a header on the board that goes off to the serial device with the tx and rx lines plus a +24v from a seperate switched mode PSU.
My question is the serial devices need a ground, do I send the ground from the 24v supply or the 12v supply? Does it even mater? Can I link the 24v switchmode supplies ground to the ATX 12v supplies ground?
Thank guys, I need to know what to do with the 2 grounds?
