umardar27
Junior Member level 1
map turbo equalization
Any one working on turbo equalization using MAP algorithm.
I have a question about calculating the gamma or the transition probability. Is it different from MAP decoder and if yes then whats the difference and if you have a matlab code portion for calculating the transition probability then if you can share it with me , i would be great ful.
Regards
Regards
