hmalissa
Junior Member level 2
- Joined
- Apr 21, 2010
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- New Jersey
- Activity points
- 1,492
I'm trying to design a circuit with 2 analog inputs (+/- 10V max. range, output impedance <1Ohm, 10mA max. current) and 1 single analog output, and I need to switch between the inputs using a TTL signal. If TTL = high, then output = input 1, and if TTL = low, then output = input 2. I was considering using 2 switches of a DG211 SPST CMOS analog switch. Would that be the most suitable approach? The frequencies of the analog input signals would be <1kHz, and I need rather high precision.
