TTL (+5v,0v) to (+5v,-5v) ?
KSA
Junior Member level 2
I have TTL logic output level +5v and 0v
I want to convert it to +5v and -5v. How to ?
KSA
Putting a MAX232 you will convert TTL levels (0-5v) to RS232 levels (-12/12V), so just a resistor divider will attenuate the voltages to your needs..
Search for ICL7660 IC
It makes this conversion.
Best regards
You can use this circuit.
Dont forget this is also inverter.
I think the solution depends on the speed you require.
regards
And why not use an MC1488 (rs232 driver) with +5V and -5V power supply ?
