Tssp77p38 ir proximity sensor and msp430f5438
Manasu24
Newbie level 3
Newbie level 3
Banglore-27
Hi guys,
i am currently searching the proper information about the output of this Tssp77p38 Ir proximity sensor.
and i want to use this in msp430f5438 to receive some data which is sent from TSAL6200 ir emiiter.
so which method would be best to capture the signal.
there are 2 ways to capture the ir signal as per my knowledge using msp430f5438
1.UART mode(if the output of tssp77p38 is UART output).
2.Timer mode(capture compare mode).
please direct me
The typical application of the TSSP77P38 is a reflective sensor with analog information contained in its output. Such a sensor is evaluating the time required by the AGC to suppress a quasi continuous signal. The time required to suppress such a signal is longer when the signal is strong than when the signal is weak, resulting in a pulse length corresponding to the distance of an object from the sensor. This kind of analog information can be evaluated by a microcontroller. The absolute amount of reflected light depends much on the environment and is not evaluated. Only sudden changes of the amount of reflected light, and therefore changes in the pulse width, are evaluated using this application.
Read the data sheet of IR proximity sensor.
