campo85
Newbie level 5
Hi all,
I state that I'm totally newbie about Cadence tools and PDK ( It's the part of the topic of my thesis ) and that my english is bad. So, I must install TSMC 65 nm PDK. I have a problem with the installation of the PDK library. I've unzipped the multi-part archive and now I have a directory with the following subdirectories :
Where do I start ? I tryed to start with the installation of 1_PDK/1_Cadence_CDBA. After many decompressions I have the following :
So, I ran the pdkInstall.pl and I answered questions about tecnology etc... :
Now, where is the library are installed ? How do i import them in virtuoso ? Can someone give me some documentation or link ? Thanks in advice and sorry for my english.
Stefano.
---------- Post added at 14:02 ---------- Previous post was at 13:53 ----------
Very good, I was wrong. I must install Cadence_OA, not Cadence_CDBA. I discovered that the libaries are automatically linked. Now, how can I disconnect the CDBA library ?
---------- Post added at 15:12 ---------- Previous post was at 14:02 ----------
How can I be sure about the successfull of installation ?
[stefano@sirio LP]$ ls
LP_All_Documents_+_Sources_updated_02122011 LP_All_Documents_+_Sources_updated_02122011.zip.004
LP_All_Documents_+_Sources_updated_02122011.zip.001 LP_All_Documents_+_Sources_updated_02122011.zip.005
LP_All_Documents_+_Sources_updated_02122011.zip.002 LP_All_Documents_+_Sources_updated_02122011.zip.006
LP_All_Documents_+_Sources_updated_02122011.zip.003
[stefano@sirio LP]$ cd LP_All_Documents_+_Sources_updated_02122011
[stefano@sirio LP_All_Documents_+_Sources_updated_02122011]$ ls
1_PDK 2_Sources_Cadence 3_Sources_Mentor 4_Sources_Synopsys 5_Documents
[stefano@sirio 1_Cadence_CDBA]$ tar xfz PDK_CRN65LP_v1.5a_official_20091103_all.tar.gz
[stefano@sirio 1_Cadence_CDBA]$ ls
CRN65LP_v1d5a_FSAChecklist_T-N65-CM-SP-007-K1.pdf REVISION
Doc_PDK_CRN65LP_v1.5a_official_20091103.tar.gz REVISION_CRN65LP_v1d5a_T-N65-CM-SP-007-K1.pdf
PDK_CRN65LP_v1.5a_official_20091103_all.tar.gz t-n65-cm-sp-007-k1_1_5a_20091208.zip
PDK_CRN65LP_v1.5a_official_20091103.tar.gz t-n65-cm-sp-007-k1_1_5a_doclist.jpg
readme TN65CMSP007K1_1_5A.pdf
ReleaseNote.txt t-n65-cm-sp-007-k2_1_5a_1_20100511_PATCH.zip
[stefano@sirio 1_Cadence_CDBA]$ tar xfz Doc_PDK_CRN65LP_v1.5a_official_20091103.tar.gz
[stefano@sirio 1_Cadence_CDBA]$ tar xfz PDK_CRN65LP_v1.5a_official_20091103.tar.gz
Assura readme
assura_tech.lib ReleaseNote.txt
Calibre REVISION
cds.lib REVISION_CRN65LP_v1d5a_T-N65-CM-SP-007-K1.pdf
CRN65LP_v1d5a_FSAChecklist_T-N65-CM-SP-007-K1.pdf skill
display.drf techfile
Doc_PDK_CRN65LP_v1.5a_official_20091103.tar.gz Techfile
models t-n65-cm-sp-007-k1_1_5a_20091208.zip
PDK_CRN65LP_v1.5a_official_20091103_all.tar.gz t-n65-cm-sp-007-k1_1_5a_doclist.jpg
PDK_CRN65LP_v1.5a_official_20091103.tar.gz TN65CMSP007K1_1_5A.pdf
PDK_doc t-n65-cm-sp-007-k2_1_5a_1_20100511_PATCH.zip
pdkInstall.cfg tsmcN65
pdkInstall.pl
[stefano@sirio 1_Cadence_CDBA]$ ./pdkInstall.pl
- TSMC Process Ddesign Kit (PDK) Install Utility V1.0a -
This perl script is used to install TSMC PDKs from the directory that
contains the original distribution source files (a super-set of PDKs) to a
specified destination directory according to the user specified options.
*Avaliable process types are:
1 - LO
2 - MM
3 - RF
Please enter your choice: (1,2...)
*Avaliable voltages are:
1 - 1.2V / 2.5V / 2.5V under-drive 1.8V / 2.5V over-drive 3.3V
2 - 1.2V / 3.3V
Please enter your choice: (1,2)
*Avaliable types of MiM cap are:
1 - MIM_1.0fF
2 - MIM_1.5fF
3 - MIM_2.0fF
*Avaliable metal options are:
1 - 1p9m_6X2Z0U_ALRDL (Support mimcap only for RF/MM )
2 - 1p9m_6X1Z1U_ALRDL (Support mimcap ,UTM inductors and RC technology files for RF/MM)
3 - 1p8m_6X1Z0U_ALRDL (Support mimcap and logic inductors for RF/MM)
4 - 1p8m_6X0Z1U_ALRDL (Support UTM mimcap and mu_a inductor for RF)
5 - 1p8m_5X2Z0U_ALRDL (Support mimcap only for RF/MM )
6 - 1p8m_5X1Z1U_ALRDL (Support mimcap and UTM inductors for MM/RF)
7 - 1p7m_5X1Z0U_ALRDL (Support mimcap and logic inductors for RF/MM)
8 - 1p7m_5X0Z1U_ALRDL (Support UTM mimcap and mu_a inductor for MM/RF)
9 - 1p7m_4X2Z0U_ALRDL (Support mimcap and RC technology files for RF/MM)
10 - 1p7m_4X1Z1U_ALRDL (Support mimcap and UTM inductors for MM/RF)
11 - 1p6m_4X1Z0U_ALRDL (Support mimcap,logic inductors and RC technology file for RF/MM)
12 - 1p6m_4X0Z1U_ALRDL (Support UTM mimcap and mu_a inductor for MM/RF)
13 - 1p6m_3X2Z0U_ALRDL (Support mimcap only for RF/MM )
14 - 1p6m_3X1Z1U_ALRDL (Support mimcap and UTM inductors for MM/RF)
*UTM inudctors include "spiral_std_mu_z", "spiral_sym_mu_z", and "spiral_sym_ct_mu_z".
"spiral_std_mu_a", "spiral_sym_mu_a", and "spiral_sym_ct_mu_a".
*Logic inductors include "spiral_std_mza_a", "spiral_sym_mza_a", "spiral_sym_ct_mza_a".
*For more information about inductor support, please refer to PDK_doc/ReleaseNote.txt
14
Please confirm with your selction information:
*** Select process : RF
*** Select voltage : 1.2V / 2.5V / 2.5V under-drive 1.8V / 2.5V over-drive 3.3V
*** Select MiM cap : MIM_2.0fF
*** Select metal option : 1p6m_3X1Z1U_ALRDL (Support mimcap and UTM inductors for MM/RF)
Are these correct (y|n) ?
y
mv: cannot stat `./Techfile/lib_bak/*': No such file or directory
====== Installing pdk library ======
Running "rm -rf ./models/eldo" ......
Running "rm -rf ./models/hspice" ......
Running "rm -rf ./models/spectre" ......
Running "cp -rf models/online/2.5V/* models/" ......
Running "cp -rf models/online/2.5V/cells.txt skill/" ......
Running "cp -rf models/misc/* tsmcN65/" ......
Running "rm -rf models/misc" ......
Running "rm -rf Calibre/online/rcx_online/calview.cellmap" ......
Running "rm -rf Assura/online/extview.trp" ......
Running "cp -rf Calibre/online/rcx_online/calview.cellmap_25 Calibre/online/rcx_online/calview.cellmap" ......
Running "cp -rf Calibre/online/rcx_online/xcell Calibre/rcx/" ......
Running "cp -rf Assura/online/extview_25.trp Assura/online/extview.trp" ......
Running "cp -rf Techfile/tsmcN65_updateCDFs.il skill/tsmcN65_updateCDFs.il" ......
Running "cp -rf Techfile/do_not_use.Cat tsmcN65/do_not_use.Cat.bak" ......
Running "cat models/online/3.3V/misc/Mosfets_33.Cat >> tsmcN65/do_not_use.Cat.bak" ......
Running macro"CLEAR_SYMBOLIC" ......
Running "rm -rf tsmcN65/M1*" ......
Running "rm -rf tsmcN65/M2*" ......
Running "rm -rf tsmcN65/M3*" ......
Running "rm -rf tsmcN65/M4*" ......
Running "rm -rf tsmcN65/M5*" ......
Running "rm -rf tsmcN65/M6*" ......
Running "rm -rf tsmcN65/M7*" ......
Running "rm -rf tsmcN65/M8*" ......
Running "rm -rf tsmcN65/M9*" ......
Running "rm -rf tsmcN65/AP*" ......
Running "rm -rf tsmcN65/met*" ......
Running "rm -rf tsmcN65/DFM*" ......
Running "rm -rf tsmcN65/rm5" ......
Running "rm -rf tsmcN65/rm6" ......
Running "rm -rf tsmcN65/rm7" ......
Running "rm -rf tsmcN65/rm8" ......
Running "rm -rf tsmcN65/rm9" ......
Running "rm -rf tsmcN65/probe" ......
Running "rm -rf tsmcN65/mimcap" ......
Running "rm -rf tsmcN65/mimcap_udc" ......
Running "rm -rf tsmcN65/mimcap_udc_3t" ......
Running "rm -rf tsmcN65/mimcap_3t" ......
Running "rm -rf tsmcN65/mimcap_um_rf" ......
Running "rm -rf tsmcN65/mimcap_woum_rf" ......
Running "rm -rf tsmcN65/mimcap_um_udc_rf" ......
Running "rm -rf tsmcN65/mimcap_woum_udc_rf" ......
Running "rm -rf tsmcN65/xjvar" ......
Running "rm -rf tsmcN65/xjvar_nw" ......
Running "rm -rf tsmcN65/moscap_rf" ......
Running "rm -rf tsmcN65/pmoscap_rf" ......
Running "rm -rf tsmcN65/pmoscap_rf25" ......
Running "rm -rf tsmcN65/lowcpad" ......
Running "rm -rf tsmcN65/moscap_rf_nw" ......
Running "rm -rf tsmcN65/moscap_rf25" ......
Running "rm -rf tsmcN65/moscap_rf25_nw" ......
Running "rm -rf tsmcN65/moscap_rf33" ......
Running "rm -rf tsmcN65/moscap_rf33_nw" ......
Running "rm -rf tsmcN65/crtmom_mx" ......
Running "rm -rf tsmcN65/MX*" ......
Running "rm -rf tsmcN65/crtmom" ......
Running "rm -rf tsmcN65/crtmom_rf" ......
Running "rm -rf tsmcN65/spiral_std_mu_z" ......
Running "rm -rf tsmcN65/spiral_sym_mu_z" ......
Running "rm -rf tsmcN65/spiral_sym_ct_mu_z" ......
Running "rm -rf tsmcN65/spiral_std_mza_a" ......
Running "rm -rf tsmcN65/spiral_sym_mza_a" ......
Running "rm -rf tsmcN65/spiral_sym_ct_mza_a" ......
Running "rm -rf tsmcN65/spiral_std_mu_a" ......
Running "rm -rf tsmcN65/spiral_sym_mu_a" ......
Running "rm -rf tsmcN65/spiral_sym_ct_mu_a" ......
Running "rm -rf tsmcN65/spiral_std_mz_x" ......
Running "rm -rf tsmcN65/spiral_sym_mz_x" ......
Running "rm -rf tsmcN65/spiral_sym_ct_mz_x" ......
Running "rm -rf tsmcN65/do_not_use.Cat" ......
Running "mv tsmcN65/parasitic_rc Techfile/lib_bak/" ......
Running "mv tsmcN65/parasitic_rc_3T Techfile/lib_bak/" ......
Running "mv tsmcN65/pcapacitor Techfile/lib_bak/" ......
Running "mv tsmcN65/presistor Techfile/lib_bak/" ......
Running "rm -rf skill/rc_*" ......
Running "rm -rf Calibre/drc/*" ......
Running "rm -rf Calibre/lvs/*" ......
Running "rm -rf Calibre/rcx/*" ......
Running "rm -rf Assura/lvs_rcx/*" ......
Running "cp -rf Techfile/online/1p6m_3X1Z1U/techfile_lib/tsmcN65/* tsmcN65/" ......
Running "cp -rf Techfile/online/1p6m_3X1Z1U/techfile ./" ......
Running "cp -rf Techfile/online/1p6m_3X1Z1U/*.Cat tsmcN65/" ......
Running "cat Techfile/online/1p6m_3X1Z1U/do_not_use.Cat >> tsmcN65/do_not_use.Cat.bak" ......
Running "mv tsmcN65/do_not_use.Cat.bak tsmcN65/do_not_use.Cat" ......
Running "cp -rf Techfile/online/1p6m_3X1Z1U/icc.rules ." ......
Running "cp -rf Techfile/online/1p6m_3X1Z1U/mapfile ." ......
Running "cp -rf tsmcN65/rm5z tsmcN65/rm5" ......
Running "cp -rf tsmcN65/rm6u tsmcN65/rm6" ......
Running "cp -rf tsmcN65/rm7a tsmcN65/rm7" ......
Running "cp -rf tsmcN65/probe_6m tsmcN65/probe" ......
Running " cp -rf tsmcN65/mimcap_6m_2p0 tsmcN65/mimcap " ......
Running " cp -rf tsmcN65/mimcap_3t_6m_2p0 tsmcN65/mimcap_3t " ......
Running " cp -rf tsmcN65/mimcap_um_rf_6m_2p0 tsmcN65/mimcap_um_rf " ......
Running " cp -rf tsmcN65/mimcap_woum_rf_6m_2p0 tsmcN65/mimcap_woum_rf " ......
Running "cp -rf tsmcN65/crtmom_rf_6m_T2u tsmcN65/crtmom_rf" ......
Running "cp -rf tsmcN65/crtmom_6m_T2u tsmcN65/crtmom" ......
Running "cp -rf tsmcN65/crtmom_mx_6m tsmcN65/crtmom_mx" ......
Running "cp -rf tsmcN65/lowcpad_6m tsmcN65/lowcpad" ......
Running "cp -rf tsmcN65/xjvar_6m tsmcN65/xjvar" ......
Running "cp -rf tsmcN65/xjvar_nw_6m tsmcN65/xjvar_nw" ......
Running "cp -rf tsmcN65/pmoscap_rf_6m tsmcN65/pmoscap_rf" ......
Running "cp -rf tsmcN65/pmoscap_rf25_6m tsmcN65/pmoscap_rf25" ......
Running "cp -rf tsmcN65/moscap_rf_6m tsmcN65/moscap_rf" ......
Running "cp -rf tsmcN65/moscap_rf_nw_6m tsmcN65/moscap_rf_nw" ......
Running "cp -rf tsmcN65/moscap_rf25_6m tsmcN65/moscap_rf25" ......
Running "cp -rf tsmcN65/moscap_rf25_nw_6m tsmcN65/moscap_rf25_nw" ......
Running "cp -rf tsmcN65/moscap_rf33_6m tsmcN65/moscap_rf33" ......
Running "cp -rf tsmcN65/moscap_rf33_nw_6m tsmcN65/moscap_rf33_nw" ......
Running "cp -rf tsmcN65/spiral_std_mu_z_6m tsmcN65/spiral_std_mu_z" ......
Running "cp -rf tsmcN65/spiral_sym_mu_z_6m tsmcN65/spiral_sym_mu_z" ......
Running "cp -rf tsmcN65/spiral_sym_ct_mu_z_6m tsmcN65/spiral_sym_ct_mu_z" ......
Running "cp -rf tsmcN65/Inductors_mu_z.Cat tsmcN65/Inductors.Cat" ......
Running "cp -rf Calibre/online/drc_online/1p6m_3X1Z1U/* Calibre/drc/" ......
Running "cp -rf Calibre/online/drc_online/ANTENNA_DRC Calibre/drc/" ......
Running "cp -rf Calibre/online/drc_online/ANTENNA_MIM_DRC Calibre/drc/" ......
Running "cp -rf Calibre/online/drc_online/LC_Pad Calibre/drc/" ......
Running "cp -rf Calibre/online/lvs_online/1p6m_3X1Z1U/* Calibre/lvs/" ......
Running "cp -rf Calibre/online/lvs_online/source.added Calibre/lvs/" ......
Running "cp -rf Calibre/online/lvs_online/xcell Calibre/lvs/" ......
Running "cp -rf Calibre/online/rcx_online/1p6m_3X1Z1U/* Calibre/rcx/" ......
Running "cp -rf Calibre/online/rcx_online/source.added Calibre/rcx/" ......
Running "cp -rf Calibre/online/rcx_online/calview.cellmap Calibre/rcx/" ......
Running "cp -rf Assura/online/1p6m_3X1Z1U/* Assura/lvs_rcx/" ......
Running "cp -rf Assura/online/techRuleSets.top2Thick Assura/techRuleSets" ......
Running "cp -rf Assura/online/lvsSwitches_DFII Assura/lvs_rcx/" ......
Running "cp -rf Assura/online/source.added Assura/lvs_rcx/" ......
Running "cp -rf Assura/online/extview.trp Assura/lvs_rcx/" ......
Running "cp -rf skill/RC_1p6m_3x1z1u/* skill/" ......
Running "mv Techfile/lib_bak/parasitic_rc tsmcN65/" ......
Running "mv Techfile/lib_bak/parasitic_rc_3T tsmcN65/" ......
Running "mv Techfile/lib_bak/pcapacitor tsmcN65/" ......
Running "mv Techfile/lib_bak/presistor tsmcN65/" ......
mv ./tsmcN65/inv_33 ./Techfile/lib_bak/
mv ./tsmcN65/inv_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nand2_33 ./Techfile/lib_bak/
mv ./tsmcN65/nand2_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nand3_33 ./Techfile/lib_bak/
mv ./tsmcN65/nand3_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nand4_33 ./Techfile/lib_bak/
mv ./tsmcN65/nand4_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nch_33 ./Techfile/lib_bak/
mv ./tsmcN65/nch_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nch_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nch_33_dnw_macx ./Techfile/lib_bak/
mv ./tsmcN65/nch_33_dnwx ./Techfile/lib_bak/
mv ./tsmcN65/nch_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nch_33_macx ./Techfile/lib_bak/
mv ./tsmcN65/nch_33x ./Techfile/lib_bak/
mv ./tsmcN65/nch_na33 ./Techfile/lib_bak/
mv ./tsmcN65/nch_na33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nch_na33_macx ./Techfile/lib_bak/
mv ./tsmcN65/nch_na33x ./Techfile/lib_bak/
mv ./tsmcN65/ndio_33 ./Techfile/lib_bak/
mv ./tsmcN65/ndio_na33 ./Techfile/lib_bak/
mv ./tsmcN65/nmos_rf_33 ./Techfile/lib_bak/
mv ./tsmcN65/nmos_rf_33_nodnw ./Techfile/lib_bak/
mv ./tsmcN65/nmoscap_33 ./Techfile/lib_bak/
mv ./tsmcN65/nor2_33 ./Techfile/lib_bak/
mv ./tsmcN65/nor2_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nor3_33 ./Techfile/lib_bak/
mv ./tsmcN65/nor3_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/nor4_33 ./Techfile/lib_bak/
mv ./tsmcN65/nor4_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/pass_33 ./Techfile/lib_bak/
mv ./tsmcN65/pass_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/pch_33 ./Techfile/lib_bak/
mv ./tsmcN65/pch_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/pch_33_macx ./Techfile/lib_bak/
mv ./tsmcN65/pch_33x ./Techfile/lib_bak/
mv ./tsmcN65/pdio_33 ./Techfile/lib_bak/
mv ./tsmcN65/pmos_rf_33 ./Techfile/lib_bak/
mv ./tsmcN65/pmos_rf_33_nw ./Techfile/lib_bak/
mv ./tsmcN65/tri_33 ./Techfile/lib_bak/
mv ./tsmcN65/tri_33_mac ./Techfile/lib_bak/
mv ./tsmcN65/moscap_rf33 ./Techfile/lib_bak/
mv ./tsmcN65/moscap_rf33_nw ./Techfile/lib_bak/
mv ./tsmcN65/inv_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/inv_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nand2_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nand2_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nand3_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nand3_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nand4_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nand4_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nor2_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nor2_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nor3_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nor3_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nor4_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/nor4_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/pass_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/pass_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/tri_33_dnw ./Techfile/lib_bak/
mv ./tsmcN65/tri_33_dnw_mac ./Techfile/lib_bak/
mv ./tsmcN65/nmos_rf_33_6tx ./Techfile/lib_bak/
mv ./tsmcN65/pmos_rf_33_5tx ./Techfile/lib_bak/
mv ./tsmcN65/pmos_rf_33_nw_5tx ./Techfile/lib_bak/
mv ./tsmcN65/pmos_rf_33_5t ./Techfile/lib_bak/
mv ./tsmcN65/nmos_rf_33_6t ./Techfile/lib_bak/
mv ./tsmcN65/pmos_rf_33_nw_5t ./Techfile/lib_bak/
*Info: PDK installation completed.
Stefano.
