The big clue is just above all the graphs in the data sheet. Note the values for the load and feedback resistors.
If you are using a split supply, the input pin should be ground referenced, try capacitve coupling with a resistor from the input pin to ground. If you are using a single supply, bias the non-inverting input at half supply voltage and break the DC link to ground in the feedback resistors by adding a capacitor in series with the ground side of the shunt resistor. At 10MHz you absolutely must add decoupling acoss the supply pins too.
Brian.
