Trying to understand Arrays in C on an Atmega16
ruriz
Newbie level 1
Newbie level 1
Hello, So I have this simple code that I am trying to understand in able to build an UTP lan tester
I would appreciate if someone can help me with this
so here is my code
assume we have an array of three types of cables and an array with a pointer to pass variables
int findType(int *v){ // the cable types
		int straight[8] = {1, 2, 3, 4, 5, 6, 7, 8};
		int cross[8] = {3, 6, 1, 4, 5, 2, 7, 8};
		int roll[8] = {8, 7, 6, 5, 4, 3, 2, 1};
		int i, ok = 0;
		for(i = 0; i < 8; i++){
			if(v[i] != straight[i]){
				ok = 1;
				break;
		if(ok == 0)
			return 0;
		ok = 0;
			if(v[i] != cross[i]){
				ok = 1;
				break;
		if(ok == 0)
			return 1; // type if cable
		ok = 0;
	int type;
	int v[8] = {0, 0, 0, 0, 0, 0, 0, 0};
//etc etc
my question is what does 'ok' do in this code , and why do I have to set it back to zero and use an if loop to return the type?
I'm sure that it is good idea to use this code. Looks like someone very newbie wrote it.
OK is a boolean variable in this case. It sets when correct cable choosen.
something like this makes more sense
		if ( checkEachType(v, straight) )  return 1;
               	if ( checkEachType(v, cross) )     return 2;
               	if ( checkEachType(v, roll) )        return 3;
		return 0;
int checkEachType(int *unknown, int *standard){
		int i;
			if(unknown[i] != standard[i]) 	return 0;
   		return 1;
