OK, so I am trying to make a transformer for use with USA wall current, i.e. 60Hz AC power. It's intended as an isolating transformer (1:1 ratio), and the secondary side is center tapped. So basically it takes the primary voltage and splits it into two oppositely oscillating sides.
You can see it on the left hand side of my circuit diagram.
So basically, my problem is that I just can't seem to build the darn thing. I got a big iron core (maybe 2 inches diameter) from a friendly professor, and I wound about 200 turns around it, with a 200 turn secondary to experiment with it. I hooked it up to a 10V sine wave function generator, and I measured something like .05V across the secondary. That is seriously awful.
I noticed that when I increased the frequency the voltage would go up, and it would max out at around 50kHz.
I used a small ferrite toroid with about 30 turns on the primary and 15 on the secondary, and I had to turn the frequency up to 40kHz to see a 7.1:4.2 voltage ratio (rms).
Is there any way to operate a transformer at 60Hz? I really don't want to have to build a frequency changing circuit, as I'm already at the limits of my circuit knowledge. What am I missing here?
