Trying I2C interface with dac (max5215) in pic24f microcontriller
Ranjitharanju
Hi I m trying to interface I2c with DAC(IC-MAx5215(slave device)) in pic24f(master device) but I am not getting the output. Even i am not getting what mistake i m doing please anyone can help me I am using system clock 32Mhz.
here is my code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
#include<p24fj128ga010.h>
#define FCY 16000000
_CONFIG1( JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2)
_CONFIG2( FCKSM_CSDCMD & OSCIOFNC_OFF & POSCMOD_HS & FNOSC_PRIPLL)
#define     bUs__idLe           0x8000
#define     i2c_disable         0x0000
#define     I2c_____conTroL     I2C1CON
void I2C_WRITE(char Mdata,char Ldata);
void start(void)
    I2C1CONbits.SEN     = 1;         //Start Condition Enable bit
    while(I2C1CONbits.SEN);          // I2C start bit verification
void stop(void)
    I2C1CONbits.PEN     = 1;         //Stop Condition Enable bit
    while(I2C1CONbits.PEN);          // I2C start bit verification
void rpt_start(void)
    I2C1CONbits.RSEN    = 1;         //Restart  Condition Enable bit
void write(char data)
    I2C1TRN = data;
int main(void)
    while(!OSCCONbits.LOCK );           //CLOCK FREQUENCY    32MHz
    I2C_INIT();
    while(1)
        I2C_WRITE(0xFF,0xFF);
    return 0;
void I2C_INIT(void)
  /*  I2C1CONbits.I2CSIDL = 1;           // STOP IN IDEL MODE
    I2C1CONbits.SCLREL  = 0;         //SCL RELESE CONTROL BIT
    I2C1CONbits.A10M    = 0;         //SLAVE ADDRESS BIT SELECT PIN
    I2C1CONbits.DISSLW  = 1;         //SLEW RATE DISABLE BIT
    I2C1CONbits.SMEN    = 0;         //SMBUS INPUT LEVEL BIT // BIT 8
    I2C1STATbits.I2COV  = 1;         //Receive Overflow Flag bit
    I2c_____conTroL     = 0x8000;
    I2C1STAT            = 0x0030;                //status bit register
    I2C1MSK             = 0X0000;                //MASK REGISTER
    I2C1BRG             = 0x4f;                  //BAUD RATE SETTING
    I2c_____conTroL     =   i2c_disable;
    __delay32(100);
    I2c_____conTroL     =   bUs__idLe ;
    __delay32(100);
    start();
    write(0X38));               //slave device address
    while(I2C1STATbits.TBF);        //waiting for complete transmission
    while(!IFS1bits.MI2C1IF);
    while(I2C1STATbits.ACKSTAT);        //waiting for slave ack
    write(0X02);                //user command address
    write(Mdata);
    write(Ldata);
    stop();
    __delay32(100);
    __delay32(100);
    __delay32(200);
void __attribute__ ((__interrupt__,no_auto_psv)) _MI2C1Interrupt(void)
  //    IFS1bits.MI2C1IF  = 0;
Thank you.
Hai,
thanks for your reply please send the code which u have i'l compare with my code.
Thank you.
part of code concerning DAC 16 bits MAX541 ( C18 Mplab)
#define Clock 0.25    // µS   at 16Mhz
#define Ualim 5.00
#define ADC_Coeff 4.096/1024.0
// DAC 16 bits SPI ali=+5V  output max==Vref=2.5V  en DIP 8
#define MAX541
#ifdef MAX541
                                    // VOut pin 1
                                    // VRef pin 3 ... +2,5V
                                    // VDD pin 8
                                    // VSS pin 7
#define MAX541_CS  LATCbits.LATC4    // CS out to pin 4
#define MAX541_SI  LATCbits.LATC1    // SI out to pin 6
#define MAX541_SCK LATCbits.LATC3    // SCK out to pin 5
#endif
#ifdef MAX541
void Out_MAX541(unsigned int V);
[COLOR="#0000CD"][I]void Out_MAX541(unsigned int V)
unsigned int i,j;
MAX541_CS=0; // CS pin 4
MAX541_SCK=0;// SCK pin 5
MAX541_SI=0; // SI pin 6
Nop();Nop();Nop();Nop();
j=32768;
// instruction byte
for (i=0;i<16;i++)
if ((V & j)==j)
MAX541_SI=1;
  else
   MAX541_SI=0;
Nop();Nop();
MAX541_SCK=0;
MAX541_SCK=1;
j=j>>1;
 MAX541_SCK=0;
Nop();
 MAX541_CS=1;
#endif[/I][/COLOR]
void Raz_Receipt()
{ptecr=buffer;
      ptlec= ptecr;
      CptCars=0;
      buffer[0]=0;
      c=0;
      receive=0;
void main(void)
#ifdef OSCILLATEUR_INTERNE
 OSCCON=0x60;         // Select8 MHz internal clock
 OSCTUNE=0;
  #ifdef WithPLL
    OSCTUNEbits.PLLEN=1;  // 1= avec PLL => 64Mhz ou 40Mhz
    #else
    OSCTUNEbits.PLLEN=0;  // 0 =sans PLL => 16Mhz  ou 10Mhz
   #endif
#endif
 Init_Hardware() ;
  Init_UART1();
 OUT_RS232
 // init sortie DAC à 0V
 Sd=0;
 [B]Out_MAX541(Sd);[/B]
 LATC=0;
 Volt=Ualim;
 k=fprintf(_H_USART,"Alim du Montage =5.0 -> %s%c",fltToa(Volt,CRam1,4),9);
 CRLF();
  // test si saisie consigne DAC MAX
   if ((CptCars>6) && (c==13)&& (buffer[0]=='M'))
     SaisieOk=0;
     for (i=1;i<6;i++)
       SaisieOk=SaisieOk+isdigit(buffer[i]);
     if(SaisieOk!=5)
        strcpypgm2ram(txt,RS_Str[5]); k=PutStr_RS(txt);
        Delay_mS(1000);
        Raz_Receipt();
      else
        buffer[6]=0; //terminateur de string
        Sd=atoi(buffer+1);       // numerique
        Volt= (float)(Sd) *2.50/65536.0;
         k=fprintf(_H_USART,"\r\nBuffer= %s Out Max541 %05u soit %s V \r\n ",buffer,Sd,fltToa(Volt,CRam1,3));
        Raz_Receipt();
