[AVR] Troubles in programmer when i try to write fuses using khazama AVR programmer
m.yassin
Newbie level 1
Newbie level 1
When i try to read or write the fuses at ATMEGA32A i get the error message which explained by image below.
can any one help me to fixed this problem ?
device signature 0x00
it's probably a hardware issue,
which programmer are you using with khazama? have you tested it before with another microcontroller?
does your circuit provides 5V vcc? does your circuit works with internal or external clock?
did it work a single time? maybe you changed the fuses wrongly...
did you tested with another AVR? maybe yours is faulty...
if your programmers is ok, and it's the first time you work with a new microcontroller, try lowering the ISP clock and program only the Flash memory, if it's ok, program your fuses and test again...
if you can't lower the ISP clock, you will have to test with avrdude directly using the "-B 3" option
