trouble in interfacing LCD to PIC16f877a
ku91l
Newbie level 6
Newbie level 6
Hello,
Please check the following HiTech C code for 16x2 LCD interfacing.
The 1st line of LCD shows blocks.The code is taken from the Samples and only the connection bits are changed.
But,its not working.
However,if I write similar code in microC,it works.So the connections are right.
Please help.
Thank You.
Also note,the HTC code is working in Proteus ISIS.
  • lcdupload.txt
yes, the code is working properly on ISIS,and yes the connections are fine too .
two things that are confusing me
1. the ISIS dig. for Pic16f877a and the one in data sheet are showing different positions of PORTD- 0 & 1 pins
2. are the < configuration bits > and the <XTal frequency causing this trouble.
Post the circuit? Is your Config settings right? Have you included HS_OSC in Config? Delay is not sufficient. Change Fosc to 4 MHz and see if it works else increase delays. If 4 MHz is used change OSC to XT_OSC in Config.
these lines are written in the code ..
[[#define _xtal_freq 16000000;
__CONFIG (0x2F0A);]]
delay value given is [ 250 ] .. (as given in the code in the 1st pdf uploaded)
* do you want to make Xtal frequency =4mhz ?*
also please confirm that denoting first pin of PORT B by [[ RB1 ]] is right or not
i.e. #define en RB1 ??
the hardware lcd i am using is on a development board so the pins Vss Vcc and Vee are already connected to the required terminals internally.There's nothing i can do in it except controlling the contrast through the potentiometer .
Can you please elaborate on the freq and config points , i suppose a mistake there
Consider the datasheet for good pins connections;VSS,VDD and VEE.
Hope its helpfull.
Nothing still ..
can you tell
1. how to define first port of PORT B in MPLAB using hitech c compiler for pic16f877a
2. what should be the configuration bits set
3. the xtal frequency defined
i have already posted the code in the first post itself as an attachment ..
here it is [[ it displays M D E to the lcd using two functions 1. lcddata 2. lcdcmd and a simple delay function
#include<htc.h>
__CONFIG (0x2F0A);
#define ldata PORTD
#define rs RB0
#define rw RB1
#define en RB2
void MSDelay(unsigned int itime);
void lcdcmd(unsigned char value);
void lcddata(unsigned char value);
void main()
TRISD = 0x00;
TRISB = 0x00;
en=0;
MSDelay(250);
lcdcmd(0x38);
MSDelay(250);
lcdcmd(0x0E);
MSDelay(150);
lcdcmd(0x01);
MSDelay(250);
lcdcmd(0x06);
MSDelay(250);
lcdcmd(0x86);
MSDelay(250);
lcddata('M');
MSDelay(250);
lcddata('D');
MSDelay(250);
lcddata('E');
ldata = value;
rs=0;
rw=0;
en=1;
MSDelay(100);
en=0;
MSDelay(100);
ldata = value;
rs=1;
rw=0;
en=1;
MSDelay(100);
en=0;
MSDelay(100);
unsigned int i,j;
for(i=0;i<itime;i++)
for(j=0;j<72;j++)
Try this with 4 MHz clock. Turn off code optimization. maybe optimization is removing the delay code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
#include<htc.h>
#define _xtal_freq 4000000;
    __CONFIG(FOSC_XT & WDTE_OFF & PWRTE_ON & CP_OFF & BOREN_ON
            & LVP_OFF & DEBUG_OFF);
#define ldata PORTD
#define rs RB0
#define rw RB1
#define en RB2
void main()
    TRISD = 0x00;
    TRISB = 0x00;
    MSDelay(250);
    lcdcmd(0x38);
    MSDelay(250);
    lcdcmd(0x0E);
    MSDelay(15);
    lcdcmd(0x01);
    MSDelay(25);
    lcdcmd(0x06);
    MSDelay(25);
    lcdcmd(0x86);
    MSDelay(25);
    lcddata('M');
    MSDelay(25);
    lcddata('D');
    MSDelay(250);
    lcddata('E');
    while(1);
    ldata = value;
    rs=0;
    rw=0;
    en=1;
    MSDelay(1);
    en=0;
    ldata = value;
    rs=1;
    rw=0;
    en=1;
    MSDelay(1);
    en=0;
    unsigned int i,j;
        for(j=0;j<72;j++)
HOW exactly do i turn off code optimisation ?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
#include<htc.h>
#define ldata PORTD
#define rs RB0
#define rw RB1
#define en RB2
void main()
    TRISD = 0x00;
    TRISB = 0x00;
    MSDelay(250);
    lcdcmd(0x38);
    MSDelay(250);
    lcdcmd(0x0E);
    MSDelay(15);
    lcdcmd(0x01);
    MSDelay(25);
    lcdcmd(0x06);
    MSDelay(25);
    lcdcmd(0x86);
    MSDelay(25);
    lcddata('M');
    MSDelay(25);
    lcddata('D');
    MSDelay(250);
    lcddata('E');
    while(1);
    ldata = value;
    rs=0;
    rw=0;
    en=1;
    MSDelay(1);
    en=0;
    ldata = value;
    rs=1;
    rw=0;
    en=1;
    MSDelay(1);
    en=0;
    unsigned int i,j;
        for(j=0;j<72;j++)
the minimum allowed value is [ 1 ] for optimization.
still not working. as you are having the code can you check if it is working or not.
It is working in Proteus. I don't have PIC16F877A with me now. Use 4 MHz Crystal or increase the delay and see. Try to use Hi-Tech C delay library routine for the delays.
