rocky79
Member level 5
- Joined
- Sep 20, 2010
- Messages
- 83
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,903
I am trying to send a PWM signal on PortC5 (PWM1) using the latest CCS compiler(5.026).
This is the manual method of sending a PWM and it doesn't seem to be working.
I have followed the PWM Setup and generation on page 221 of PIC16f1503 datasheet. I just couldn't get it to work. Anyone have anyidea what else I should be doing?
#include <16F1503.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOMCLR
#use delay(clock = 4000000)
#USE FAST_IO (C)
//GPIO BIT ASSIGNMENT FOR I/O REGISTERS PORT A
//address of the TRISIO registe
#byte TRISC = getenv("SFR:TRISC")
#byte PORTC = getenv("SFR:PORTC")
#bit PORTC_1=PORTC.1
#word ANSELC = getenv("SFR:ANSELC")
// setting up PWM parameters
#byte PR2= getenv("SFR:PR2")
#byte T2CON=getenv("SFR:T2CON")
#word PWM1CON= getenv("SFR:PWM1CON")
#word PWM1DCH=getenv("SFR:PWM1DCH")
#word PWM1DCL=getenv("SFR:PWM1DCL")
#bit PWM1DCL_7=PWM1DCL.7
#bit PWM1DCL_6=PWM1DCL.6
#byte PIR1=getenv("SFR:PIR1")
#bit PIR1_1=PIR1.1
int16 duty;
#bit duty_0=duty.0
#bit duty_1=duty.1
void pwm(int16 value);
void main()
int16 i;
//----------------------manual PWM config--------------------------------
//SET ALL PORT C PIN DIGITAL
ANSELC=0x0;
//Disable the PWM pin (CCPx) output driver(s) by
//setting the associated TRIS bit(s) to INPUT
//TRISC= 0b00111111;
//TRISC= 0x0;//OUTPUT
//Clear the PWM1CON register.
PWM1CON=0x0;
//Load the PR2 register with the PWM period value.
PR2=255; // 255hz
//Clear the PWMxDCH register and bits <7:6> of
//the PWMxDCL register.
//Load the CCPRxL register and the DCxBx bits of
//the CCPxCON register, with the PWM duty cycle
//value.
duty = 0; // set duty cycle to 0
PWM1DCH=0x0;
PWM1DCL_6 = 0; // Store duty to registers as
PWM1DCL_7 = 0; // a 10-bit word
delay_ms(5);
//Configure and start Timer2:
//clear the TMR21F interrupt flag bit of PIR1 register
PIR1_1=0;
delay_ms(5);
//START TIMER2 Set prescaler(64) AND POSTSCALER
T2CON=0b00000111;
//Configure the T2CKPS bits of the T2CON register
//with the Timer2 prescale value.
//0000 =1:1 Postscaler
//1 = Timer2 is on
//10 = Prescaler is 16
//11 = Prescaler is 64
//Enable PWM output pin and wait until Timer2
//overflows, TMR2IF bit of the PIR1 register is set.
PWM1CON=0b10000000;
wait_for_TMR2IF:
if (PIR1_1 == 0)
goto wait_for_TMR2IF;
//Enable the PWMx pin output driver(s) by clearing
//the associated TRIS bit(s).
TRISC=0x0;
//and setting PWM1OE bit of the PWM1CON registeR
PWM1CON=0b11000000;
//SET A PWM VALUES To START
duty=0;
PWM1DCL_6 = duty_0; // Store duty to registers as
PWM1DCL_7 = duty_1; // a 10-bit word
PWM1DCH = duty >> 2; // store the remaining low byte}
while(1)
for(i=0;i<1020;++i)
//Output a PWM wave
//set_pwm1_duty(i);
pwm(i);
delay_ms(3);
//int16 value;
duty=value;
PWM1DCH = duty >> 2; // store the remaining high byte}
