i searched all over the cadence help files for a solution to do a very simple task.
In waveform window, how can i remove the crosshair markers A and B once they have been set.....i don't want to change their position (i just have to click a or b again)...but i want to remove them altogether........i can't hide them and its just teasing me ......
thank u for your comment, but actually what i am asking about is something different.
once i have a plot in the waveform window, i can place place markers and crosshairs from the markers menu....but once i place the A or B crosshairs i can only change their position ....what i want to do is to hide them completely
Yep it is trivial. But it took me years before I found out.
TO remove A and B marker you should click with the mouse to the center of the xhair marker by that I mean to the point where the vertical and horizontal part of the marker cross.
It is kinda hard in my opinion....
When the selection of the marker is correct there will be a little star next to the A or B. Then you can hit "delete" key. If the star is not there you will delete the wave.
You actualy do not have to click directly to the center but close to it..
Wavescan is supposed to do better job than AWD. But sadly I found that Wavescan is toooo slow on our current hardware. So I have to give it up and go back to the old AWD.
