smanjume
Junior Member level 1
- Joined
- Nov 2, 2010
- Messages
- 17
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Activity points
- 1,365
what is the output if triangular and impulse signal applied as input to the inductor?
Are you talking about current as output?? else put a schematic..
inductor voltage = - L di / dt
It depends on the circuitry you choose, for example when inductor and resistor in series now you have look the resistor voltage for current output and inductor voltage for monitoring voltage variations..
simply for applying triangular current through inductor you will have square wave across it...........
for applying square wave current you will get spikes of voltage output.........
