drcoyle65
Newbie level 2
- Joined
- Jul 1, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 22
I have several questions about this TRIAC interface circuit. I am trying to build a circuit that is very similar, except that it will primarily use 120V 60Hz. It is fine if it works for 120/230V and 50/60Hz. The incandescent bulb will be no more than 75W.
My first question is about the MOC3021 and MT136 devices. There seems to be several varieties, especially with the MT136. Are there specific ones that you would recommend?
What are the wattage rating of R1, R2, and R3? Are they 1/4 watt or 1/2 watt?
What gauge wire are you using for the main power?
Would it be easily adaptable to have the output go to an outlet and then plug the corded light into the outlet?
The input to the circuit is coming from the PWM section of a microprocessor. Is the triac triggered from the positive or negative portion of the waveform?
Any other information would be greatly appreciated.
