avbeek
- Joined
- Feb 2, 2015
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Netherlands
- Activity points
- 57
According to the example circuit in the manufacturer's datasheet of the LS7232 (touch control dimmer), the following circuit is independent of the AC line polarity:
I made some changes to the input of the LS7232, resulting in this circuit:
I used all advised component (values) except for the triac. The datasheet mentions a Q4006L4 but I used a BT137-600E instead because I could not get a Q4006L4. Problem is that my dimmer is now dependent on how you plug in the lines plug. It only functions when the neutral wire is on the MT2 side of the triac.
Could it be that I use the wrong (type of) triac?
