Scolioza
Member level 1
- Joined
- Mar 5, 2013
- Messages
- 34
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,561
Hi all, folks !
I have no experience in designing power electronics. I have a small automation project. The requirements are to switch on and off some vents. according with temperature. The client wants to be able to use manual and auto mode.
The uc. part was easy but since I dont have experience with power electronics I thought that it would be a good idea to ask another opinion, so I came to you.
I have the following concerns:
1. It's ok the way I fire the main triac?
2. The snubber is ok? (all vents consumption is 250 W)
3. For the optotriac is ok the trigger circuit?
4. Is there a problem with the switches?
5. The driver that the vents are using now is also made with triacs, because the client wants to be able to change speeds of vents manually. The triac that I want to use will act as a relay. But since I use zero crossing optotriac I am thinking that it will be a problem, because inside the current driver it might be another zero crossing triac and it's triacs will not fire.
Thank you in advance.
PS Please excuse my english
