transmission line issue
henry kissinger
Member level 2
The transmission used here has characteristic impedance of 60Ohm at the voltage pulse Tr=0.1 nsec
I am using a repeating voltage pulse to get the information of the characteristic impedance of the transmission line.
When the pulse drops to 0.3V, the node drops to 0.558V because at this short period it is seeing the transmission line as a resistor of 60Ohm
I learnt that this short period is the time for the signal to travel across the transmission line.
However if I increases the length of transmission line from 5cm to 20cm, the first pulse seems ok, the time it takes to travel across the line is 4 times and it is still dropping to 0.558V. But the successive pulses are not accurate, which deviates from 0.558V and have a weird shape.
What causes this I still don't understand? and how should I fix it? to let 20cm usable.
The transmission line has characteristic impedance of 60 Ohm.
How to explain that the voltage at 'node' oscillate between 0.558V(1-0.7*(60/95)) and 1.442V(1+0.7*(60/95)) ?
I only know that in stable situation it should be 1V, but what it is confusing is during the transition of the pulse.
What do you expect? You are driving a shorted transmission line and have no correct source termination. Results in multiple reflection that superimpose during the pulse train. What's the intended waveform?
The waveforms in your simulation are smoothed, most likely due to limited time resolution in the simulator settings. To see the response of an ideal transmission line, you should use finer resolution, as in the below LTspice simulations. I don't know the substrate parameters and respective exact transmission delay of your circuit, I tried to create similar delays.
Here the voltage steps caused by reflections running back and forth the line van be seen much better.
To predict the step voltages, you need to calculate the reflection and transmission factors for the discontinuities in the transmission line circuit. First discontinuity is from pulse generator to TL, Rs=35, Rl=60, T=60/95 as you calculated. Second discontinuity is at the shorted line end, R= -1, voltage step is running back inverted. Third discontinuity is line to source, Rs=60, Rl= 35. R=(35-60)/(35+60)=-0.26, T=2*35/(35+60)=0.74. Respectively -0.44 V pulse is partly transmitted and partly reflected again. See also https://en.wikipedia.org/wiki/Reflections_of_signals_on_conducting_lines#Discontinuity_along_line
With each roundtrip, the pulse is attenuated to about 1/4. With short transmission line, the multiple reflections have almost faded away before the next source edge. In case of the long line, the reflections are still enduring, causing a more complex superseeded waveform.
--- Updated ---
A detailed discussion can be e.g. found in Hall/Heck, Advanced Signal Integrity for High-Speed Digital Designs, Paragraph 3.5 Transmission-Line Reflections.
Thank you for great and explain. I totally get your concept!
but Can you explain a little more why the original voltage change decay to 26% after each round trip?
Initially the voltage at node get reflected and remain 60/(35+60) =63%
but why it decay to 26% after a round trip? I dont get it how T=2*35/(35+60)=0.74 comes from?
The transmission used here has characteristic impedance of 60Ohm.
When the pulse drops to 0.3V or goes back to 1V, Initially the voltage at 'node' changes by 0.7*60/(35+60) = 0.442V, why is it calculated this way? I learnt the reflection coefficeint is calculated as ZL-Z0/ZL+Z0 tho, which is different to how I get the 0.442V.
also why it decay to 26% after each round trip? How do I get this result based on calculation with reflection coefficient?
Round trip attenuation is the product of R at both ends, -1 and -0.26, as calculated above. The voltage you see at the line input isn't the reflected voltage, it's the sum of original and reflected pulse, 2*Z2/(Z1+Z2), see also Wikipedia link above. Between source and line input, factor 2 doesn't occur because you relate the measurement to unloaded rather then 35 ohm loaded voltage. Instead you get the simple voltage divider for transmitted pulse.
