akjyani
Newbie level 5
Hi all,
I have designed a CPWG transmission line in EMPro using RO3003 substrate. I calculated the dimensions for 50 ohm transmission line at 60 GHz. But after simulation at 60 GHz its not showing 50 Ohm. At lower frequencies it is showing constant 50 ohm but at higher frequency it is changing abruptly. I have attached the result snapshot here. Could anyone suggest me why this is happening?
or this material (RO3003) is not valid at higher frequency ? but in data sheet it is written that it is valid till 77 GHz.
Any help would be appreciated.
Thank you.
Thank you.
