Translator and cmos driver
_Mark81_
Newbie level 6
Newbie level 6
Inverigo (CO) - Italy
[SOLVED]: Translator and cmos driver
I need to translate a 3.3V clock signal to 5V in order to feed 100 cmos logic gates.
The clock frequency is very low, but I do need very sharp edges, say a rise/fall time below 50 ns.
What do you recommend?
I think any open-drain configuration is not suitable due to the pull-up resistor. I'm going to use a standard level-translator and a push-push mosfet driver.
Anyway I'm looking for a solution with very few parts.
Thanks in advance
You might consider a simple 74HCT or 74ACT series Schmitt
trigger (e.g. 74ACT14) and a high drive octal buffer (or just
use the remaining 5 Schmitt inverters of the hex). The input
of the T (TTL compatible) input ought to be tolerant of not
being driven to rail.
Let's see... cost might be a little lower, but the parts count is doubled, board space is quadrupled (one 8-pin and Vcc capacitor versus one 14-pin plus one 20-pin plus 2 Vcc capacitors) and output current is halved (1+A versus 8*48mA = 0.4A).
I'll give it a try with this IC:
https://www.ti.com/lit/ds/symlink/ucc27323.pdf
it costs about 1 euro for 100+ pieces, it has a huge current output (no need so much current, though) and it doesn't require any voltage translator at input. Furthermore it's a double driver - my board has 2 clock signals to handle :lol:
Good choice. You may actually NEED the drive current because your cmos inputs are highly capacitive and the driver chip will give you good clean transitions without clock skew.
