hmm...not exactly . Even at 2.4GHz u can have 9.6kBPS or 20kHz BW .
Having said that , it's true as BW given by the standard body is the % of the frequency you transmit .So as u increase the frequency , you will get larger bandwidth.
Bandwidth of what ? Amplifier ? With or without feedback ?
If you want a detailed and correct answer you should try to formulate the question as exact as possible.
