Transister Detector (Digital electronics project for beginner)
Eshal
Advanced Member level 1
Nowhere :)
Hello experts!
How are you all?
I have digital electronics in this semester but now my semester is up to end. So I have been given to create project. I am thinking of design the transistor detector. Means, if I place transistor in the circuit then LED should glow if transistor is alright. And if transistor is bad then LED should be off. I think this can be a simple project. But I don't know where should I start.
My senior told me to design as it is a simple project. So experts, help in design this simple project.
Remember,
TTL should be consider only.
Thank you very much.
Hi Eshal,
Please go through the link:
https://www.google.co.in/url?sa=t&r...=w1lnX9YcfrRF2MPuEnOJhg&bvm=bv.45175338,d.bmk
Hope this helps!!
Hi Eshal,
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&ved=0CD0QFjAB&url=http%3A%2F%2Fncra.tifr.res.in%2F~baddi%2FSTT.pdf&ei=z-5nUbpAxbiuB7CSgfAM&usg=AFQjCNHuta1BO5e1fL8hBxh9jQHzY8Tu8g&sig2=w1lnX9YcfrRF2MPuEnOJhg&bvm=bv.45175338,d.bmk
Hope this helps!!
Ohh.. thank you very much. It brings alot of help. But if you help me step by step via block diagrams then it will be good then
Regards,
Princess.
@Prashanthanilm
Hello sir!
I read your given pdf. But it is about whether transistor is NPN or PNP. While I need a project about faulty transistor detector.
Thank you.
Oh yes, It is for NPN and PNP.
Hey you can google it right you will lot of options.
I suggest you to go through some sites, look how different the projects are.
If any doubts you can ask here.
Yes, I have googled it already. But nothing I found like it is a faulty transistor detector.
