I've got this little transformer from my power suply 12Vdc 500mA,
I'd like to use it as converter 12V -->200V to charge up condensators 4700uF to approximately 200Vdc,
i"ve used ne555 to switch transistor with 8Hz to supply secondary winding with 8V and 2A, but max output in primary winding was only 7Vdc<graetz bridge> because of transistor serious heating <tip120>
no matter where i've put voltage, secondary or primary winding, output was the same, max 7Vdc with ne555 and by hand 10Vdc,
Am I doing something wrong? or there is better way to do this?
Thank for Your guidance,
