yo2550
Member level 2
- Joined
- Nov 26, 2011
- Messages
- 44
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,675
There is no sound from the speaker when in RX mode. The RX circuit seems to be working fine as you can see it picks up the signal and shows RX on the screen.
The mic(sound input) is not working as well as I tested it by pressing the PTT, speak to the mic and listened from the other transceiver, the signal goes out but there is no voice at the other transceiver.
I already tried turning the volume to the maximum but still no sound.
Seems to be an analog circuit problem but I am not sure which parts I should check and replace. I checked the circuit board and did not see any parts broken.
Please advise. Thanks.
Here is the diagram.
Note: The turn-on beep sound works, the setting beep sound works, the call sound come out from the transceiver speaker but it is not transmitted into the air(the transmitting circuit works but no sound come with it).
