abuholm
Newbie level 3
- Joined
- Nov 8, 2008
- Messages
- 4
- Helped
- 19
- Reputation
- 38
- Reaction score
- 18
- Trophy points
- 1,283
- Location
- Ghana West Africa
- Activity points
- 1,310
Hi everyone i have a toshiba laptop a205 , and it has a perculiar problem..it works ok on battery alone without any problem.. and it also works ok when the adaptor is plugged in with the battery out.. without any hassle, but when i plug in the adaptor with the battery inserted then violaa!! laptop freezes..also when the laptop is off with the adaptor plugged in,the battery charges normally..now,when the machine is in the off state with both battery and charger inserted and i power it on, it doesn't boot to the desktop,but freezes halfway..
I took it apart and made some analysis.. when the battery is inserted,nothing heats up on the board..when adaptor alone is inserted,nothing heats up..but when both charger and battery are inserted and battery is charging,these components heat up and they are all around the battery connector: 4845Px2, 6900AS,BQ24721C and inductor coil with 100 written on it ..ooh and another thing, the adaptor makes a high pitch humming noise a few seconds after the adaptor is plugged in the machine..i have tried several adaptors and they all behave the same way..i want to know which component to change..any help will be appreciated..i have uploaded a pic of the board and the components labeled are the ones that heat up..i tested the mosfets and they seem fine..any help will be appreciated
