Mar 18, 2019 #1 Z Zak28 Advanced Member level 2 Joined Aug 19, 2016 Messages 579 Helped 6 Reputation 12 Reaction score 6 Trophy points 18 Activity points 4,681 is it fine to not use ring terminals and just torque tinned copper wire right into the barrier terminal block on the power supply? for these types of supplies https://www.mouser.com/ProductDetail/709-LRS150F-12
Mar 18, 2019 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,155 Helped 4,868 Reputation 9,757 Reaction score 5,535 Trophy points 1,393 Activity points 168,328 Hi, manually tinned wires are a no-go for reliable and especially for high current connections. The tin is weak and will loose contact force with time. The best are crimped contacts - but only with a suitable, high quality crimp tool. If you need details, do a search for "gas tight crimping". Klaus
Mar 18, 2019 #3 Z Zak28 Advanced Member level 2 Joined Aug 19, 2016 Messages 579 Helped 6 Reputation 12 Reaction score 6 Trophy points 18 Activity points 4,681 KlausST said: Hi, manually tinned wires are a no-go for reliable and especially for high current connections. The tin is weak and will loose contact force with time. The best are crimped contacts - but only with a suitable, high quality crimp tool. If you need details, do a search for "gas tight crimping". Klaus Click to expand... The wires I use aren't manually tinned they are completely tined by factory, I don't tin the ends with solder. Wouldn't soldering the ring terminal onto the wire be just as good as crimping it? Last edited: Mar 18, 2019
Mar 20, 2019 #4 W wwfeldman Advanced Member level 4 Joined Jan 25, 2019 Messages 1,101 Helped 231 Reputation 461 Reaction score 297 Trophy points 83 Activity points 8,554 no high quality crimp, especially gas tight crimp, is a really good mechanical contact solder is used as glue to hold good mechanical connections in place. solder should not be the connection
