messlia
Newbie level 5
I am designing a solar application for charging up the batteries, the variable output to be 3V to 12V to be to used to charge up the 5V battery... I though of using the LM7508 to bring the voltage to a fixed voltage of 5v but the 5V at the output requires at least the input to be 1 to 2 V then the output... i though of increasing the input voltage to a higher voltage level but if the voltage level is too high then this will heat up the LM7508.
Need suggestion as how to go about on the input of this LM7508
suggestions and guidance is be welcomed....
Thank you
Thank you
