TMS320LF2406A Copy
pao33
Newbie
Newbie level 3
hello friends, there is a need to copy the tms320lf2406a processor dump, the CCS 3.3 win xp 32, xds510usb program is installed, tell me in detail how to do it? transfer a program from a processor to a new processor
You need to have the firmware file to program a microcontroller.
If you have the source code, then you need to compile it to get the firmware file.
If you have neither, you need to contact the manufacturer/programmer of the original code.
Otherwise ... it sounds like you try to steal the work of another person. No one will help you with this. ( Maybe I've written the code ;-) )
Klaus
not to steal at all, but to restore the processor, the port is faulty, and the controller sees the program, when replacing the processor there is a need to flash the processor
the reading procedure is as follows ....file-data - save- programs , everything is readable , I downloaded the dump, the processor is not blocked, but there is a suspicion that it is necessary to create a new project to collect all the files and create an output file
writes an error in the program during firmware
