[SOLVED] TMR0 Problem Regarding Time Calculations
thir13enth
Member level 1
Quezon City, Philippines
Microcontroller = PIC16F877A
Oscillator = 20MHz XT
Compiler = MikroC
Hello, I am trying to work my Timer 0 with my PIC. Unfortunately, I cannot make it work the way I wanted it to. There is no error when I compile my program, but when I try to simulate it in Proteus, it gave fast outputs. Here is my code:
unsigned count;
void main() {
 OPTION_REG = 0xE4; // gie = peie = tmr0ie = tmr0if = 1
 TRISD = 0x00;
 PORTD = 0x00;
 TMR0 = 0;
 INTCON = 0x07; // PS0 = PS1 = PS2 = 1 set to 1:256
 do {
    count++;
    if (count == 76) {
      PORTD = ~PORTD;      // Toggle PORTB LEDs
      count = 0;             // Reset cnt
  } while(1);
What I need is to lengthen its duration. Say for example, 2 seconds. Anyone who has a tutorial on how to do do the calculations especially the preload value? I want to learn how, of course based with my PIC which is PIC16F877A.
Regards,
Gello Mark C. Vito
int Counter=0;
void interrupt()
	 INTCON=0x20;						//Clear the GIE and the T0IE
	 TMR0=0;                            //Re-initialize TMR0 register
	 ++Counter;                         //Increment the dummy variable
void main()
 	 TrisB=0;                           //Configure PortB as Output
 	 TrisA=255;                         //Configure PortA as Input
 	 PortB=0;                           //Initialize portB
	 INTCON=0xA0;                       //Enable the GIE abd T0IE
	 OPTION_REG=0x85;                   //Set the prescale to 64
	 TMR0=0;                          //Initialize the Timer0 register
	 /* These values of the prescaler and the TMR0 as well as the dummy variable will ajust the
	  interrupt to fire every 1 second
	 while(1)
			 if (Counter==64)
			    portb=~portb;         //Toggle portb status
			    Counter=0;            //Reset the dummy variable
The oscillator is 4MHz.
Hope this helps.
I really appreciate the effort. Though I would greatly appreciate if you can explain to me how to come up with the values.
Thanks.
Gello Mark C. Vito
You can try this pic timer calculator
Alex
I appreciate the efforts though for the second time, I would want to insist knowing the calculations. This is our final year project, so it is very critical and essential for me to know the calculations details by details.
Thanks,
Gello Mark C. Vito
