oac
Newbie level 5
- Joined
- Jan 27, 2014
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 62
i'm having trouble with a very basic issue here. It concerns the TI TL-082 opamp: http://www.ti.com/lit/ds/symlink/tl082.pdf
I'm using it as a the schmitt trigger in the schematic here: http://www.piclist.com/images/www/hobby_elec/e_ckt16.htm. But after the output "7" i put an additional resistor to limit zener current and two zener diodes in series to mass, to clip the output voltage.
The datasheet specifies the supply current with no load as typically 1.4mA. There's no short circuit output current specified. It can deliver more current to a finite load, right?
It specifies the maximum power dissipations, but i don't know how to use these figures...
Can someone give me a clue?
Thank you in advance...
