Hello, Im designing a PSU with 3 switching elements and 1 LDO. One is a flyback (fs max 100khz) and the 2 others are buck (fixed 500khz and 2.1Mhz). Do you having 3 switching elements on the same pcb will cause a problem? Can you give me any advice regarding layout or any other issue that might cause problem?
Three problems could occur:
-ripple intermodulation (causing larger peak values)
-increased EMI
-perhaps one of the switchers sporadically losing control.
All of the science and black magic of designing a good PSU lies in in the PW board layout. It really is the key "component" in a PSU.
There is a lot of reading available on the web...............it is simply to much information to answer on a post.
yes there is pcb layout guide for smps for you here...in post #7............just keep tight current loops.......dont run power switching currents along long lengths of control gnd. https://www.edaboard.com/showthread.php?t=371528
