emperror123
Member level 5
- Joined
- Dec 11, 2010
- Messages
- 86
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,880
hi guys
currently i m facing problem in implementing TEA in VHDL. the program can be compile successfully, but unfortunately the data has no output, i have no idea why.
below are my coding
the warning showed
hope u all can help me out
below are my coding
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity TEA is
port(
clk : in std_logic;
input : in std_logic_vector (63 downto 0);
key : in std_logic_vector (127 downto 0);
encript, decript : out std_logic_vector (63 downto 0)
end TEA;
architecture TEA of TEA is
signal k0, k1, k2, k3: std_logic_vector(31 downto 0);
signal n: integer:=0;
begin
k0<=key(127 downto 96);
k1<=key(95 downto 64);
k2<=key(63 downto 32);
k3<=key(31 downto 0);
process (clk, input)
variable z, z1, z2,z3,zt,y, y1, y2, y3, yt: std_logic_vector (31 downto 0);
variable sum: std_logic_vector (31 downto 0) ;
variable delta: std_logic_vector (31 downto 0) ;
begin
delta := x"9E3779B9";
sum := x"00000000";
if rising_edge(clk) then
if (n=0) then
y:= input(63 downto 32);
z:= input(31 downto 0);
else if (n=32) then
sum:=delta(26 downto 0) & "00000";
end if;
if (n<32) then
sum:=sum+delta;
z1:= ((z(27 downto 0) &"0000")+k0);
z2:= (z+sum);
z3:= (("00000"& z(31 downto 5))+k1);
zt:= z1 xor z2 xor z3;
y := y+zt;
y1:= ((y(27 downto 0) &"0000")+k2);
y2:= (y+sum);
y3:= (("00000"& y(31 downto 5))+k3);
yt:= y1 xor y2 xor y3;
z := z+yt;
encript <= y&z;
else if (n<64) then
y2:= (y+sum);
z := z-yt;
z2:= (z+sum);
y := y-zt;
sum := sum-delta;
Decript <= y&z;
end if;
end if;
n<=n+1;
end if;
end if;
end process;
end TEA;
the warning showed
Warning: Feature LogicLock is not available with your current license
Warning: No exact pin location assignment(s) for 321 pins of 321 total pins
Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
Warning: Found 128 output pins without output pin load capacitance assignment
Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'.
Warning: Found pins functioning as undefined clocks and/or memory enables
Info: Assuming node "clk" is an undefined clock
