[SOLVED] timing problem in doing CLOCK DOMAIN CROSSING
achaleus
Member level 5
Bangalore
While doing CDC, I am using 3 flop synchronizer from slow clock(100MHz) to fast clock(250MHz).
It is reporting timing not met as (I am using xilinx 14.7 for synthesis)
Source Clock: clk_100 rising at 10.000ns
Destination Clock: user_clk rising at 12.000ns
but actually it should report
Source Clock: clk_125 rising at 10.000ns
Destination Clock: user_clk rising at 4.000ns
so, what thing do I need to modify in UCF.
Vinay
dpaul
Advanced Member level 5
Germany
I don't understand your description below.
Considering data travel path from the left to the right, data is passing from 100MHz to 250MHz domains. For a 3 flop sync stage, the 1st flop will be clocked at 100MHz and the next 2 flops at 250MHz. This is what I know is the std procedure.
More details are required including the UCF.
ads-ee
Super Moderator
Staff member
USA
It's showing 12 instead of 4 because the edge at 3*4 (12) is the worst edge (draw it out to scale).
With ucf there isn't a nice clock is async command like SDCso you will have to resort to using TIG (timing ignore group) between the clocks.
achaleus
Member level 5
Bangalore
with TIG, it simply ignores the timing for all those paths with cdc even if it is not meeting (considering all those paths which are failing), so I don't know whether that is an efficient way. I didn't get why you have written 3*4
vGoodtimes
the 100 MHz clock has rising edges at 10ns, 20ns, 30ns ...
the 250 MHz clock has rising edges at 4ns, 8ns, 12ns, 16ns, 20ns ...
the 12ns edge of the 250 MHz clock is 2 ns after the 10 ns edge of the 100 MHz clock.
ads-ee
Super Moderator
Staff member
USA
That is the point of using it, you can't reliably time the CDC as it won't meet setup/hold at every clock edge relationship.
And why do you think you have to meet timing in a CDC path? The whole point of a CDC is the clocks are not synchronous and therefore there is no assumed timing relationship between the clocks.
vGoodtimes
The constraint that is desired is "max skew". For fifos, the address is gray coded (in most implementations). TIG literally means you could delay bit 0 by 1 microsecond, bit 1 by 2 microsecond, etc... Very absurd. But it could easily violate the gray code "one bit changes on increment" property.
There is also an assumed max delay constraint. For example, delay should not be more than one day. (again absurd, but TIG allows it).
(This is nothing against ads_ee, I just feel that Xilinx's support of TIG and wildcard names was lazy "wonderfullness" that should have never been a thing.)
ads-ee
Super Moderator
Staff member
USA
Yeah, couldn't agree more. TIG IMO was the wrong way to constrain a CDC, I came from an ASIC background with SDC and did manual placement and routing for FPGAs with RLOC constraints on the CDC FFs (due to poor performance ofthe automated P&R, but you use what they give you).
