Hi
My question is i am using 2 scenarios func worst and func best.my default scenario is func worst .i did placement and it worked fine.i did cts too in default scenario and after that if i do report timing clock is propagated by default with out set propagated clocks command in icc
When i change to func best the clock is not propagated it is showing idle.what is the reason? If i give the command set propagated clocks then in the report for hold it is taking propagated clocks but with huge clk network delay.this is my main problem.why it is taking so huge values for hold when it is taking value for setup? Why clock is not propagated for hold scenario?
I have main clocks and also virtual clocks in the design.another issue is report timing to any clock path for both setup and hold also is giving path unconstrained? Why is it so??
Please clarify i am specifying all the required files sdc scenario info and all.
This is my show stopper.please give me a solution ASAP.
