TOOLs and Tech: Questasim 10.5c-2 / Synopsys design_vision I-2013.12 / STM 65nm
Hi
I am running some timing simulations on my design and have some doubts and issues with the results.
1- My design is synthesized with Clk_Period = 2 ns and the timing report of the design shows it could meet the timing completely (slack (MET) = +1.75). To me it means that 2 ns is more than enough to meet the required setup and hold time of each flip-flop from the technology standard libraries. However, after simulating the netlists, it seems it has problem with delivering data from registers in 2 ns and it need the data to be stable for more than that (having 4 ns between two consecutive changes seems to be enough to get data out from the output of register) the following attachment shows this issue:
2- Simulatiing the netlists versus the SDF back annotated files gives me errors regarding the hold time:
# ** Error: PATH_TO_STANDARD_CELL_LIBRARY_BEHAVIORAL_FILE(25913): $hold( posedge CP:6 ns, negedge D &&& dE:6 ns, 14 ps );
# Time: 6 ns Iteration: 1 Instance: :Test_Design_tb
UT: Register1_reg_2_
All above problems happen while report_constraint -all_violators gives: "This design has no violated constraints."
and report_timing shows positive slack for the paths
3- In another design of mine I have a memory IP block. when doing SDF simulation I am getting several issues:
sdf simulation stops with FATAL error (several errors of two different types:
# ** Error (suppressible): (vsim-SDF-3261) PATH_TO_SDF_FILE.sdf(107919): Failed to find matching specify module path.
# ** Error (suppressible): (vsim-SDF-3262) PATH_TO_SDF_FILE.sdf(107923): Failed to find matching specify timing constraint.
** Fatal: (vsim-SDF-3444) Failed to annotate from SDF file PATH_TO_SDF_FILE.sdf
# Time: 0 ps Iteration: 0 Instance: :sram_mult_top_tb File: PATH_TO_TESTBENCH_FILE.vhd Line: UNKNOWN
# FATAL ERROR while loading design
# Error loading design
using vsim -sdfnoerror to reduce errors to warnings helps running the simulation, however still with following two type warnings (errors reduced to warnings)
and running the simulation it has several timing issues for resolving the out values.
I am wondering if I really need to modify the sdf content with respect to IP and if so, how?
I appreciate any hint or help about above issues.
