djc
Advanced Member level 1
- Joined
- Jan 27, 2013
- Messages
- 402
- Helped
- 3
- Reputation
- 6
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- India
- Activity points
- 4,554
I wrote a program for pic18f4520 interfacing with 4*4 matrix keypad and 15 FND and 74hc595 using Timer 0 interrupt. Issue is display is running fine on timer interrupt but key detection is not working. However if i disable timer interrupt and display key status separately its working fine. Can anybody plz tell me what is the probem. Plz guide. Here is my code
#define ROW0 PORTB.B1
#define ROW1 PORTB.B3
#define ROW2 PORTB.B5
#define ROW3 PORTB.B7
#define COL0 RB0_bit
#define COL1 RB2_bit
#define COL2 RB4_bit
#define COL3 RB6_bit
#define Select_DS PORTD.B7
#define Select_Clk PORTD.B6
#define Data_DS PORTD.B5
#define Data_Clk PORTD.B4
#define TIMER_START_VALUE 0
unsigned int arr_small[10] = {24,222,52,148,210,145,17,220,16,144};
unsigned int arr_large[10] = {17,125,35,37,77,133,129,61,1,5};
unsigned int arr_med[10] = {20,126,140,44,102,37,5,124,4,36};
unsigned int Select_FND[4] = {1,2,4,8};//{16,32,64,128,256,512,1024,2048,4096,8192,16384,32768};
unsigned int decimalNumber,remainder,quotient,decimalNumber_1,remainder_1,quotient_1;
unsigned int binaryNumber[100],binaryNumber_1[100],i=1,j,k,l_1=0,l=0,l_3=0,l_4=0,m=0,count=0,key,flag=0;
unsigned int key_fnd_0, key_fnd_1, key_fnd_2, key_fnd_3;
unsigned int Data=0,FND_0=255,FND_1=255,FND_2=255,FND_3=255,FND_4,FND_5,FND_6,FND_7,FND_8,FND_9,FND_10,FND_11,FND_12,FND_13,FND_14,FND_15;
/*void Sel_FND(int select)
quotient = select_fnd[select];
i=1;
while(quotient!=0){
binaryNumber[i++]= quotient % 2;
quotient = quotient / 2;
for(j = i-1;j> 0;j--){
Select_DS = binaryNumber[j];
Select_Clk = 1;
Delay_us(10);
Select_Clk = 0;
Select_Clk = 1;
Delay_us(10);
Select_Clk = 0;
void Key_Detect(int Data)
quotient = Data;//arr_small[key];
i=1;
while(quotient!=0){
for(i=i;i<=8;i++)
binaryNumber[i] = 0;
Data_DS = binaryNumber[j];
Data_Clk = 1;
Delay_us(10);
Data_Clk = 0;
Delay_us(10);
Data_Clk = 1;
Delay_us(10);
Data_Clk = 0;
//Delay_ms(1000);
void interrupt()
if(INTCON.TMR0IF){
TMR0L = TIMER_START_VALUE;
T0IF_bit = 0;
Select_DS = 1;
Delay_us(2);
Key_Detect(arr_small[FND_0]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
Key_Detect(arr_small[FND_1]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
Key_Detect(arr_small[FND_2]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Delay_ms(1000);
Key_Detect(arr_small[FND_3]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
Key_Detect(arr_large[FND_5]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_large[FND_6];
Key_Detect(arr_large[FND_6]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_large[FND_7];
Key_Detect(arr_large[FND_7]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_large[FND_8];
Key_Detect(arr_large[FND_8]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
Key_Detect(arr_med[FND_9]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_med[FND_10];
Key_Detect(arr_med[FND_10]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_med[FND_11];
Key_Detect(arr_med[FND_11]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_med[FND_12];
Key_Detect(arr_med[FND_12]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_med[FND_13];
Key_Detect(arr_med[FND_13]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_med[FND_14];
Key_Detect(arr_med[FND_14]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
//Data = arr_med[FND_15];
Key_Detect(arr_med[FND_15]);
Select_Clk = 1;
Delay_us(2);
Select_DS = 0;
Select_Clk = 0;
void main() {
TRISD = 0x00; //PortD as output
PORTD = 0x00; //Initial value
TRISB = 0b01010101;
INTCON = 0xc0;
TMR0ON_bit = 0; //Stop timer 0 during set up
TMR0IE_bit = 1; // Enable TMRO interrupt
T08BIT_bit = 1; // Enable 8 bit control
T0CS_bit = 0; // use internal clock to trigger timer to count
PSA_bit = 0; // Use the prescaler to slow the timer down
// prescaler
// 111 = 1:256 Prescale value
// 110 = 1:128 Prescale value
// 101 = 1:64 Prescale value
// 100 = 1:32 Prescale value
// 011 = 1:16 Prescale value
// 010 = 1:8 Prescale value
// 001 = 1:4 Prescale value
// 000 = 1:2 Prescale value
T0PS0_bit = 0;
T0PS1_bit = 0;
T0PS2_bit = 0;
TMR0ON_bit = 1; // start the timer
flag = 2;
/*FND_0 = flag;
FND_1 = flag;
FND_2 = flag;
FND_3 = flag;*/
FND_4 = 4; //Default values on FND 5 to 15
FND_5 = 5;
FND_6 = 6;
FND_7 = 7;
FND_8 = 8;
FND_9 = 9;
FND_10 = 0;
FND_11 = 1;
FND_12 = 2;
FND_13 = 3;
FND_14 = 4;
FND_15 = 5;
while(1){
while(1){ //Keypad displayroutine
ROW0 = 0;
ROW1 = 1;
ROW2 = 1;
ROW3 = 1;
Delay_ms(50);
while(COL0==0){
do
Delay_ms(5);
}while(COL0!=1);
key=1;
count++;
//Sel_FND(1);
//Key_Detect(arr_small[1]);
//if (Button(&PORTB, 2, 1, 0))
//FND_6 = 1;
while(COL1==0){
do
Delay_ms(5);
}while(COL1!=1);
key=2;
count++;
//Sel_FND(2);
//Key_Detect(arr_small[2]);
while(COL2==0){
do
Delay_ms(5);
} while(COL2!=1);
key=3;
count++;
//Sel_FND(4);
//Key_Detect(arr_small[3]);
while(COL3==0){
do
Delay_ms(5);
}while(COL3!=1);
key=0;
count++;
//Sel_FND(8);
//Key_Detect(arr_small[0]);
ROW0 = 1;
ROW1 = 0;
ROW2 = 1;
ROW3 = 1;
//PORTB.B3 = 0;
Delay_ms(5);
while(COL0==0){
do
Delay_ms(5);
}while(COL0!=1);
key=4;
count++;
while(COL1==0){
do
Delay_ms(5);
}while(COL1!=1);
key=5;
count++;
while(COL2==0){
do
Delay_ms(5);
} while(COL2!=1);
key=6;
count++;
while(COL3==0){
do
Delay_ms(5);
}while(COL3!=1);
key=0;
count++;
ROW0 = 1;
ROW1 = 1;
ROW2 = 0;
ROW3 = 1;
//PORTB.B5 = 0;
Delay_ms(5);
while(COL0==0){
do
Delay_ms(5);
}while(COL0!=1);
key=7;
count++;
while(COL1==0){
do
Delay_ms(5);
}while(COL1!=1);
key=8;
count++;
while(COL2==0){
do
Delay_ms(5);
} while(COL2!=1);
key=9;
count++;
while(COL3==0){
do
Delay_ms(5);
}while(COL3!=1);
key=0;
count++;
ROW0 = 1;
ROW1 = 1;
ROW2 = 1;
ROW3 = 0;
//PORTB.B7 = 0;
Delay_ms(5);
while(COL0==0){
do
Delay_ms(5);
}while(COL0!=1);
key=0;
count++;
while(COL1==0){
do
Delay_ms(5);
}while(COL1!=1);
key=0;
count++;
while(COL2==0){
do
Delay_ms(5);
} while(COL2!=1);
key=0;
count++;
while(COL3==0){
do
Delay_ms(5);
}while(COL3!=1);
key=0;
count++;
if(count==1){
key_fnd_0 = key;
FND_0 = key_fnd_0;
else if(count==2){
key_fnd_1 = key;
FND_1 = key_fnd_1;
else if(count==3){
key_fnd_2 = key;
FND_2 = key_fnd_2;
else if(count==4){
key_fnd_3 = key;
FND_3 = key_fnd_3;
if(count>4){
FND_5 = 0;
count=0;
