May 21, 2003 #1 SphinX Advanced Member level 3 Joined Jan 25, 2002 Messages 822 Helped 58 Reputation 116 Reaction score 29 Trophy points 1,308 Location EGYPT Activity points 7,045 time delay generator for 8051 Hi, I found a simple program for calculate a time delay for 8051 uc. I write simple blink program too to test this program. It's just a led blink every 1s (1000000 us) I used the delay routine generated from above program. It very helpful for beginner. Program+Blink Example in ASM and Proteus here. Bye Pharaoh Of Egypt
May 22, 2003 #2 P pringles Newbie level 4 Joined May 22, 2003 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 55 timer delay in 8051 hi, do you have a time delay calculator for PIC?
May 22, 2003 #3 Fragrance Advanced Member level 4 Joined Jul 26, 2002 Messages 1,190 Helped 248 Reputation 496 Reaction score 202 Trophy points 1,343 Location East Of Earth Activity points 8,933 timer delay in 8051 pringles said: hi, do you have a time delay calculator for PIC? Click to expand... This was uploaded in past search the forum Fragrance
May 22, 2003 #4 SphinX Advanced Member level 3 Joined Jan 25, 2002 Messages 822 Helped 58 Reputation 116 Reaction score 29 Trophy points 1,308 Location EGYPT Activity points 7,045 calculating time delay in c 8051 Hi, Delay generator for PICs Bye
Jul 2, 2003 #5 M MegaVolt Newbie level 1 Joined Aug 2, 2002 Messages 0 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,280 Activity points 40 8051 delay calculation hi, do you have a time delay calculator for Dallas 80c320?
Nov 12, 2003 #6 M marine_zjh Newbie level 3 Joined May 10, 2003 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 24 8051 time delay calculator that is very good, but the exe exit after I enter the the MHz and time to delay, I don't know why. coulde you send me that caculter again via Email: marinezhang@motorola.com thanks a lot!!!
Nov 12, 2003 #7 SphinX Advanced Member level 3 Joined Jan 25, 2002 Messages 822 Helped 58 Reputation 116 Reaction score 29 Trophy points 1,308 Location EGYPT Activity points 7,045 time delay in 8051 Hi, You must run the program from the dos prompt. start->run-> write "command" press ALT+Enter run the program by write c:\time8051 (if you unzipped the file in c ) Bye
Nov 12, 2003 #8 M marine_zjh Newbie level 3 Joined May 10, 2003 Messages 3 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 24 calculate time delay 8051 Thanks I got that, but that code is in ASM. do you have any such program for C. thanks!!
Nov 12, 2003 #9 SphinX Advanced Member level 3 Joined Jan 25, 2002 Messages 822 Helped 58 Reputation 116 Reaction score 29 Trophy points 1,308 Location EGYPT Activity points 7,045 8051 time delay Hi, U can insert the asm code inside the C code easily, Many c compilers do that like that void delay (void) { # asm { ;your asm code } #endasm } bye
Oct 29, 2010 #10 K ktwei Newbie level 4 Joined Oct 29, 2010 Messages 6 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,320 IT WORKS. THKS:razz:
Apr 9, 2011 #11 #MAAM# Full Member level 2 Joined Nov 21, 2009 Messages 131 Helped 29 Reputation 58 Reaction score 27 Trophy points 1,308 Location Egypt Activity points 1,920 thank you alot
