Even if the transistor optocoupler were capable of withstand the peak voltage of a 220 volt sinewave (which it won't by a factor of at least 10), it does NOT provide a HARD TRIGGER, which is absolutely necessary for the SCR to latch.
You doubly compound the problem by using a four SCRs, where for the application you only require two plus two diodes.
This is best accomplished via pulse transformers, like so (the schematic is only partial):
SCR motor controls have been used for at lest 40 years, without requiring a single IC, only a unijunction transistor, like these one which also does not require a pulse transformer, because it only uses two common-cathode SCRs:
