Through-hole via in Agilent Momentum
usx
Member level 2
I want to insert multi-layer via into and I drew one using this tutorial.
https://abhargava.files.wordpress.com/2013/10/via-simulations-using-ads.pdf
The problem is that in the tutorial, they simulate via filled with conductor. What I want is a through hole via with metal thickness of several mil that is open and the two conducting planes do not cover it.
volker@muehlhaus
Advanced Member level 5
Skin effect will cause current flow on the via surface only, so it makes no difference in results if you model a hollow via or filled. Current flows on the surface only in both cases.
That was the physics part. Now the tool part: Momentum internally meshes the surface of conductors, so that the EM solution uses a "hollow" via anyway. You could draw the via as a donut, but it really makes no difference except for the effective series resistance that Momentum uses for the via side walls.
For the pad, you can draw them as a donut if you wish. To cut out the center, draw a circle with the hole diameter on the metal layer, then use Edit > Merge > Union Minus Intersection.
