three way uneven Wilkinson Power Divider
raed_microwave
Kassel, Germany, Germany
uneven divider
Hi
I'm designing three way uneven wilkinson power divider for three stage Doherty Power Amplifier. I need some examples about the ratios that use in the three stage Doherty amplifier to design the Power Divider.
Thanxxxxx for help
uneven three-way split
General Design Equations of N-Way Arbitrary Power Dividers
uneven power drive
Thanx burton for your help, but I know how to design N way Wilkinson Power Divider and I have already designed this power divider, my problem is that I need ratio values that use for uneven power drive multistage doherty amplifier e.g. the ratio that use in 3 stage doherty amplifier and I need to know why this ratio used for this amplifier.
thanxx in advance....
You don't need a divider but a coupler. Depending on the coupling factor more or less power is split off the main line.
