this idea will work? (2 PLLs for quadrature generation)
Eugen_E
Full Member level 6
Full Member level 6
Romania
Hello,
I want to ask if its possible to generate quadrature clock signals using 2 input signals with a small phase shift between them, applied to 2 PLLs like in the image.
I know about obtaining quadrature signals using 2 flip flops and an inverter, but I want to use the above circuit - with PLL, because the maximum frequency of the VCO in the PLL is limited, and I can't aford the frequency division with 2.
Please tell me if this will work, and if the frequency dividers implemented as cascaded flip-flops should be reset at the start, to ensure proper phase shift, or the PLLs wil take care of this?
Thank you.
If you are making your own PLL ( IC ) then you can build a quadrature VCO.
Otherwise, you can use a polyphase circuit to generate the quadrature signal without frequency division ( and without need for 2 PLLs )
    Eugen_E
Another method is to generate the signal at 4x the required frequency and then use a 1/4 johnson counter.
