Hello,
I have a question concerning the derivation of the thevenin equivalent circuit shown on page 16 (upper part) in
https://www-soc.lip6.fr/~hassan/lec3_single_stage.pdf
I know that the small signal equivalent of a diode connected transistor corresponds to a 1/gmb resitor.
It is also clear how to retrieve the gain Av in the left circuit directly (by KVL/KCL).
But I'm missing an systematic way of how to get from the left circuit to its Thevenin equivalent.
I would proceed as follows:
- the Thevenin equivalent is calculated by considering only Vin and the gm-current source (the circuit part with 1/gmb is not considered in the calculation since it is left the same in the Thevenin equivalent circuit)
- for the Thevenin equivalent resistance it is then clear: short-cut Vin and get a diode connected transistor 1/gm.
But how to retrieve the thevenin equivalent voltage source value Vin?
- If I measure the voltage of the open-circuited Vout in the left circuit (ignoring the 1/gmb part of the circuit as mentioned above) I cannot retrieve any voltage "Vin" since the gm-current source is ideal.
- If I add the 1/gmb part to the calculation then it's not a "real" Thevenin equivalent" anymore (consisting of only a voltage source and a "single" resistor)
Does someone know what is missing in my approach?
Thanks in advance!
