Jester
Full Member level 6
I'm trying to determine if a simple voltage regulator circuit will operate within its allowable temperature range.
The device package is TO-252 (0.4 deg C/W), soldered to PCB that will act as a heatsink.
Power dissipated by the device is (12-5) * 0.25 = 1.75 Watts
Using TI's thermal calculator, it appears that if I have 8"^2 of copper, the regulator will be hot but should be within it's range.
However the PCB will be mounted in a sealed (gray) metal enclosure with a surface area of 0.5ft^2 and located outdoors in full sunlight. The maximum ambient temperature in this location will be 45 deg.C
Assuming 14W/ft^2 of solar energy, the enclosure would need to dissipate a total of 1.75 + 7 = 8.75W
Based on this calculation: **broken link removed**
It appears the temperature rise in the enclosure would be about 6 deg C (seems low?)
If that's correct the maximum temperature on the board would be about 90 deg C
Does this look correct?
