bukhaari077
Newbie level 2
function ber=dscdma(Marray,N,SNR,mode,...
rate,coding,interleaver,v,gdb,delay,...
flat,fading,Nc,ua,Nuser)
%%%Pengirim
% x=[1 0 0 1 0 0 1 1 0 1 1 0];
% N=1000;
n=log2(Marray); %--> JUmlah bit yang akan dimodulasi menjadi 1 simbol
% N=N*rate+n-mod(N*rate,n); %--> Mengubah jumlah bit yg diproses
%agar menjadi kelipatan dari jumlah bit pada 1 kali proses modulasi
for ii=1:Nuser
x(ii,
=randint(1,N,[0 1]);
%Convolutional Coding --> menambahkan bit spy di penerima bisa memperbaiki
%error
if rate==1/2
trellis=poly2trellis(8,[255,162]);
elseif rate==1/3
trellis=poly2trellis(9,[557 663 711]);
elseif rate==2/3
trellis = poly2trellis([5 4],[23 35 0;0 5 13]);
end
if coding==1
outcoding=convenc(x(ii,
,trellis);
elseif coding==0
outcoding=x;
end
%Blok Interleaver
if interleaver==1
baris=4;kolom=4;
blok=baris*kolom;
outint=zeros(1,size(outcoding,2));
for i=1:size(outcoding,2)/blok
outint(1,blok*i+1-blok:blok*i)=matintrlv(outcoding(1,blok*i+1-blok:blok*i),...
baris,kolom);
end
elseif interleaver==0
outint=outcoding;
end
% konversi biner ke desimal dg asumsi MSB di sebelah kiri
outdes=zeros(1,length(outint)/n);
for i=1:length(outint)/n
outdes(1,i)=bi2de(outint(1,n*i+1-n:n*i),'left-msb');
end
%Modulasi/Mapping
% outmod=pskmod(x,2);
if mode=='psk'
outmod=pskmod(outdes,Marray);
elseif mode=='qam'
outmod=qammod(outdes,Marray);
maxt=max(abs(outmod));
end
%Spreading
h=hadamard(Nc);
ct(ii,
=repmat(h(ii,
,1,size(outmod,2));
outpulse=rectpulse(outmod,Nc);
outspread(ii,
=ct(ii,
.*outpulse;
end
outsum=sum(outspread,1);
ind=1;
% SNR=0:2:20;
% tic
%Fading Rayleigh
if fading==1 %SInyal kirim terkena kanal fading
if flat==1
%Flat fading
h=raygen(size(outsum,2),v);
outfading=h.*outsum;
else
%Freq. Selective Fading
h1=raygen(size(outsum,2),v);
h2=raygen(size(outsum,2),v);
gdb=10.^(gdb/10);
p1=[zeros(1,delay(1,1)) outsum(1,1:end-delay(1,1))].*h1.*gdb(1,1);
p2=[zeros(1,delay(1,2)) outsum(1,1:end-delay(1,2))].*h2.*gdb(1,2);
outfading=p1+p2;
h=(h1*gdb(1,1)+h2*gdb(1,2))/2;
end
elseif fading==0 %Sinyal Kirim tidak terkena kanal fading
outfading=outsum;
end
for snr=SNR
%%%%Buat Noise AWGN
outawgn=awgn(outfading,snr+10*log10(log2(Marray)/Nc),'measured');
%Ekualisasi ZF
if fading==1
outek=outawgn./h;
else
outek=outawgn;
end
%Despreading dan integrator
outdespread=ct(ua,
.*outek;
outint=intdump(outdespread,Nc);
%%%Penerima
%Demodulasi/Demapping
if mode=='psk'
outdemod=pskdemod(outint,Marray);
elseif mode=='qam'
maxi=max(abs(outint));
outdemod=qamdemod(outint*maxi/maxt,Marray);
end
%Konversi desimal ke biner dg asumsi MSB di sebelah kiri
outbin=zeros(1,length(outdemod)*n);
for i=1:length(outdemod)
outbin(1,n*i+1-n:n*i)=de2bi(outdemod(1,i),n,'left-msb');
end
if interleaver==1
%Blok Deinterleaver
outdeint=zeros(1,size(outbin,2));
for i=1:size(outbin,2)/blok
outdeint(1,blok*i+1-blok:blok*i)=matdeintrlv(outbin(1,blok*i+1-blok:blok*i),...
baris,kolom);
end
outdeint=outbin;
end
%Blok viterbi decoding
if rate ==1/2
traceback=(length(outdeint)/2)-1;
elseif rate ==1/3
traceback=34;
elseif rate==2/3
traceback=34;
end
if coding==1
datadekoding=vitdec(outdeint,trellis,traceback, 'trunc', 'hard');
elseif coding==0
datadekoding=outdeint;
end
%Menghitung BER
[p,ber(1,ind)]=symerr(x(ua,
,datadekoding);
ind=ind+1;
end
% toc
% close all
% semilogy(SNR,ber,'r-*'),xlabel('SNR (dB)'),ylabel('BER')
% grid on
%Tugas : Buat Grafik BER-SNR 3 jenis modulasi berbeda,
% BPSK, QPSK, 8PSK, Jumlah data 10000 bit, SNR:-6 s.d. 20
%Supaya mudah dan efisien, program utk menghitung BER dipisahkan
% dari program utk membuat grafik
function modulasipsk
N=100;
f=1;
x=[1 1 0 1 0 0 0 1 ];
% y=[1 1 1 1 1 1 1 1 0 0 0 0 1 1 1 1 ]
y=rectpulse(x,N);
fs=N;
t=0:1/fs:1-1/fs;
% t=linspace(0,1,fs)
carrier1=sin(2*pi*f*t);
carriertot=repmat(carrier1,1,length(x));
y=2*y-1;
outmod=y.*carriertot;
close all
subplot(321),plot(x,'linewidth',3)
title('Bit Sebelum dimodulasi'),grid on
subplot(322),plot(y,'linewidth',3)
title('Bit Yang dijadikan Pulsa'),grid on
subplot(323),plot(carrier1,'linewidth',3)
title('Sinyal Carrier'),grid on
subplot(324),plot(carriertot,'linewidth',3)
title('Sinyal Carrier Total'),grid on
subplot(326),plot(outmod,'linewidth',3)
title('Sinyal Setelah dimodulasi'),grid on
function latihannomor3
n=3;
x=[0 1 ];
for i=1:n+1
x(1,i+2)=x(1,i)+x(1,i+1);
end
function latihannomor2
n=5;
% h=eye
% p=rot90(eye
% y=h|p
y=eye
| rot90(eye
%%%Pengirim
% N=1000;
for ii=1:Nuser
x(ii,
%error
if rate==1/2
elseif rate==1/3
elseif rate==2/3
end
if coding==1
elseif coding==0
outcoding=x;
end
%Blok Interleaver
if interleaver==1
baris=4;kolom=4;
blok=baris*kolom;
baris,kolom);
end
outint=outcoding;
end
end
%Modulasi/Mapping
if mode=='psk'
elseif mode=='qam'
end
%Spreading
h=hadamard(Nc);
ct(ii,
outspread(ii,
end
ind=1;
% SNR=0:2:20;
% tic
%Fading Rayleigh
if flat==1
%Flat fading
else
gdb=10.^(gdb/10);
outfading=p1+p2;
end
outfading=outsum;
end
for snr=SNR
%%%%Buat Noise AWGN
%Ekualisasi ZF
if fading==1
outek=outawgn./h;
else
outek=outawgn;
end
outdespread=ct(ua,
%%%Penerima
if mode=='psk'
elseif mode=='qam'
end
end
if interleaver==1
%Blok Deinterleaver
baris,kolom);
end
outdeint=outbin;
end
if rate ==1/2
elseif rate ==1/3
traceback=34;
elseif rate==2/3
traceback=34;
end
if coding==1
elseif coding==0
end
%Menghitung BER
ind=ind+1;
end
% toc
% close all
% grid on
N=100;
f=1;
y=rectpulse(x,N);
fs=N;
t=0:1/fs:1-1/fs;
y=2*y-1;
close all
n=3;
x=[0 1 ];
for i=1:n+1
end
n=5;
% h=eye
% p=rot90(eye
% y=h|p
y=eye
