Theory about AC - AC Converter
Ntinos
Newbie level 3
Athens, Greece
Hi all from Greece. I have to design a system which has these specifications:
a) Input Voltage 220 Volts and 50 Hz
b) Output Voltage 117 Volts and 60 Hz
c) SPWM control
d) The RMS of the Input Voltage has + - 10% fluctuations or variances.
I cannot use transformer.
Can you help me? Can you suggest me a good free site on Internet for studying this subject? Thank you.
See this like starting idea :
  • FRM025.pdf
Reactions: Ntinos
    Ntinos
It will hardly implement the 50/60 Hz frequency conversion.
Generally speaking, the hardware of a typical single phase motor inverter is what you need:
Input rectifier, bus capacitor, PWM controlled H-bridge, output inductor, possibly a sine filter.
If high input power factor is required, the AC/DC stage would use inductor plus H-bridge as well.
Reactions: Ntinos
    Ntinos
Yes, I agree... Where can I find this theory on internet? Thank you. What I have to look for?
