[Theoretical Question] Long data sequence filtering
camancunian
Newbie level 2
Newbie level 2
Hi all,
I have a question related to filtering a long data using FFT convolution.
To start, let me explain my understanding about convolution in time domain.
Let x is time domain long input signal that has L points.
Let h is time domain filter kernel that has M points.
The length of y will be N=L+M-1 if y = x*h, i.e. y is the output of convolution between x and h in time domain.
The length of y will also be N=L+M-1 if we use N-FFT convolution instead.
Let N=L+M-1 and N fortunately is the power of two.
First, we zero padded the input x and filter kernel h so that both have length of N points.
Second, take N-FFT of zero padded-x and h and multiply them, yielding output Y in frequency domain.
Third, take N-IFFT to produce y that has N=L+M-1 points.
The problem arises if I segment the long data x to be small blocks and filter them independently (here the filter is same for all blocks).
Refer to a book by Proakis (DSP: Principles, algorithms, and application 3rd edition, page 430-433), there are two methods for doing so: overlap-save method and overlap-add method.
I clearly understand about how overlap-add method works. It simply yields the overall filtered output y that has length L+M-1 points. Each filtered output block will extend M-1 points to the right since we have added the input block by M-1 zeros. By overlapping addition the most right block will extend to the right by M-1 points and these points that make the overall filtered output y has M-1 point-extension.
My problem is about overlap-save method.
The key procedure is just for the first block we define the most left M-1 points to be zeros, while the other blocks gather the most left M-1 points from the previous block. It is shown that using this method the overall filtered output y will have length of L, which is confusing. I bet this is because we define M-1 points at x(-1:M-1) to be zeros (something that we don't bother in overlap-add method). This definition has consequence of deletion of the most left M-1 points of the overall filtered signal y (due to deletion of the most left M-1 points of each block).
If discarding the most left M-1 points in overlap-save method is allowed, it is logical to neglect the most right M-1 points in overlap-add method. However, why is it not the case ?
Hope you all shed light on my problem or give recommendation books to read about this particular difficulty. Thanks in advance.
So sad there is no one who replies this thread.
However, I have got the answer.
For overlap-save method, we need to be aware that the attached figure is misleading. We need to make sure that the last block needs to have zero-valued for at least the most right M-1 points, otherwise take another block and extend it to be zeros for the undefined points.
Cheers
