The simple way to cut PCB
sat30
Junior Member level 1
Anyone knows a simply way to cut PCB? Any advice for a home-made tool?
Thanks in advance
a good hack saw with a fine blade, but wear a mask!!
pd
Thin Fiber-glass PCBs can be cut using a big scrissor. Bakellite (brown) pcbs can be cut using a paper knife . But you will need a hack-saw to cut normal pcbs made of fiber.
Re: Any way to cut PCB??
Friend of mine who made a lot of PCB's at home used a heavy duty guillotine and smoothed off the sides with a mounted disc sander.
I have built a cuting tool for PCB. I used a diamond saw blade on a DC motor and fixed it on a metal plate
I'm using decoupling saw for this.It is so cheap to buy it.Guillotines are also good for this but 3 times expensive than decoupling saw :)
Analyzer.
I have a dremel clone, a mini drill with a lot of accessories.
I use it for cut PCB with cutting disks and to make holes.
It was not more expensive (about 35 €)
I have used a "Goscut" nibbler before, although it only nibbles away 1/2" at a time it managed to cut boards OK, sanding them down afterwards.
You can also use a small bandsaw, a tile cutting saw etc.
Can you show a pic? Or specify the device? Thanks.
I use a robust paper ghiliotine, and work very fine
Would you give us a link where you bought it? Or can you show us a picture of this tool? I'm interested.
Analyzer.
