chang830
Full Member level 5
I found the psrr in some books is defined as the ratio between the gain from the input to the output and the gain from the supply to the output. In other books and some product datasheets,it is defined it as the ratio of the change of output and the change of the power supply.
Same questions applied to the CMRR definition. I wonder what's the descranpancy between these two defintions? Or in what conditions, I should use whaich one of them?
Thanks
Thanks
